Dark mode doesn't work
mak_kawa
Post by mak_kawa »
Probably since Ver.1.99, the dark theme is added, but doesn't work.
When I set theme to dark mode from setting dialog, no problem, and the "style" value in xnconvert.ini is set to "-2".
Reopen XnConvert, display theme is certainly dark, but theme setting is automatically reverted to default in setting dialog.
And again reopen XnConvert, theme is default (light mode), and the style value in xnconvert.ini is changed to "0".
Weird...
Re: Dark mode doesn't work
right, will be fixed
