Show JXL EXIF metadata
Hacker
Post by Hacker »
Please implement reading JXL EXIF metadata (such as Aperture, ISO, etc.). ExifTool already supports reading (and writing) such metadata.
Thanks for considering.
Roman
masterjp
Re: Show JXL EXIF metadata
Post by masterjp »
This is a great idea. The stable jpeg xl version 0.9.0 is now available and support it.
I hope to see it in one of the next releases of XnViewMP.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
please sned me a sample file with EXIF?
Hacker
Post by Hacker »
Hello Pierre,
Attached is a normal .jpg, converted using cjxl (https://github.com/libjxl/libjxl) to .jxl while keeping existing metadata, readable with ExifTool.
TIA
Roman
PXL_20240223_170853802.jpg.jxl.zip
(1.97 MiB) Downloaded 75 times
ExifTool shows EXIF on this file?
mudo_j
Post by mudo_j »
xnview wrote: Wed Mar 13, 2024 3:12 pm ExifTool shows EXIF on this file?
ExifTool shows exif metadata, you might have some sort of "issue" with it.
Hacker
Post by Hacker »
Seems to work fine, thank you very much!
Roman
