Allow "Save As" to save to current folder
exener
Post by exener »
When I perform a "Save As" operation, I typically want to save a copy of the image to the same folder as the current image, but with a different name.
XnView MP seems to always default to the desktop folder for the "Save As" operation.
Is there a way to allow "Save As" to default to the current folder (the folder that contains the current image)?
If not, could such an option be added?
mrwul
Re: Allow "Save As" to save to current folder
Post by mrwul »
Looked thru the changelog (viewtopic.php?f=82&t=47125)
Maybe it is listed there and I am overlooking it...
I was seeking for the same and checked out XnViewMP Settings and found something under "File Operations"
SnagIt-12052024 085739.png (11.57 KiB) Viewed 1021 times
Maybe this helps?
I think these settings should be ticked by default, as this is pretty much the default behaviour:
- For 'Save as', use original pathname
- For 'Save as', use original format
Kadet
Post by Kadet »
user0 wrote: Sun May 12, 2024 7:22 am I think these settings should be ticked by default, as this is pretty much the default behaviour:
Not for me. I set off "'Save as', use original format".
