1.82 Translation questions & answers
Xyzzy
Post by Xyzzy »
What does this option do:
#define TXT_Option_Reset_XY "Reset X/Y"
Where in the GUI do I find:
#define TXT_TemplateMenu_Filename_Number "Filename Number"
#define TXT_BrowseMenu_Open_Container_Folder "Open container folder"
#define TXT_Thumbnail_For_Folder "Show thumbnails on folder"
#define TXT_Browse "Browse"
#define TXT_Iptc_Time_Created "Time created"
#define TXT_Iptc_Release_Time "Release time"
#define TXT_Iptc_Sent_Date "Sent date"
#define TXT_Iptc_Sent_Time "Sent time"
#define TXT_Iptc_Close "Close"
#define TXT_Adjust_Smooth "Smooth"
#define TXT_SeqConvert_Switch_WH_Orientation "Switch Width and Height to follow orientation
#define TXT_Listing_Replace_Backslash "Replace '\\' by '/'
#define TXT_String_Transformations "Transformations
#define TXT_String_EXIF_Date "EXIF Date"
#define TXT_String_EXIF_Date_Descending "EXIF Date (descending)"
#define TXT_String_TB_Filter "Filter
The rest is already done.
X.
Re: 1.82 questions
Xyzzy wrote:What does this option do:
Set X/Y to 0 when using file next/previous
Popup menu to add info (fullscreen, view, slideshow)
In context menu after a search
No more used :-)
Search dialog
IPTC dialog
Rotate dialog
Convert dialog after adding resize
Generate listing dialog
Tab in convert dialog
Sort option in batch rename
Tooltips for new icon in mini toolbar
Xyzzy
Post by Xyzzy »
Thanks.
However for the life of me I cannot make Reset X/Y work.
X.
Xyzzy wrote:However for the life of me I cannot make Reset X/Y work.
I'm not clear how this is supposed to work, either. I've zoomed into an image, locked zoom, then navigated to next. -> Position was reset
There's definitely a better name for this option, e.g. "Reset image position" (but first we have to understand what it actually does).
Post by Guest »
Xyzzy wrote: However for the life of me I cannot make Reset X/Y work.
When you are in 'Fit to window width/height', and you use file prev/next, the position of picture is always reset to 0
Xyzzy
Post by Xyzzy »
OK, I got it.
So we have another option that is improprely named, non-obviously depends on other option and should work another way anyway (for all auto image sizes/also in fullscreen).
On the bright side, it is properly placed in Options.
X.
While translating to German I also have some questions:
- Where are the following strings used:
#define TXT_NviewMenu_Clean "Clean..."
#define TXT_NviewMenu_Levels "Levels..."
- What does this one exactly do:
#define TXT_String_Auto_Levels "Auto levels"
Does it affect colours or also brightness?
helmut wrote: #define TXT_NviewMenu_Clean "Clean..."
Clean metadata
Difficult ot explain, it's based on a histogram, to change black/white point
Rearrange levels based on histogram
