tga to png lossing alpha
y2keeth
Post by y2keeth »
tga to png losing alpha channel just turns white
Re: tga to png lossing alpha
could you post a sample file?
y2keeth
Post by y2keeth »
when i convert PNG to TGA, the output TGA is in 32bits, do you use actions?
y2keeth
Post by y2keeth »
xnview wrote: Sun Mar 17, 2024 7:47 am when i convert PNG to TGA, the output TGA is in 32bits, do you use actions?
is there away to keep them 24 bit?
I need to keep them type 2 for a game
you can add a 'change depth' action
y2keeth
Post by y2keeth »
xnview wrote: Mon Mar 18, 2024 7:37 am you can add a 'change depth' action
ok I will try that thanks
