XnViewMP 1.6.0 - Saving single AVIF file does not work!
masterjp
Post by masterjp »
Thank you first for your hard work and release of version 1.6.0!
:arrow: 1. File menu => save as => avif file format
I opened a png file and saved it to the avif format (different compression settings tested e.g. Quality 80%, Format 420, Speed =5).
:bug: Error-Message: An error occurred during saving :!:
In the german translation the program says: 'File could not be renamed'.
The german translation of the same error is different!
Maybe it helps you to faster find the error. Thank you!
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnViewMP 1.6.0 - Saving single AVIF file does not work!
hm, I have issues with other formats, but could not reproduce error with AVIF (tried different settings)
If you have installed the setup, please rename libde265.dll into de265.dll
masterjp
Post by masterjp »
I did a fresh install of the XnviewMP.exe and get the error message.
Now I tried the xnviewmp.zip file and avif file saving works fine!
You are right. It is a problem of the wrong filename of the x265 library.
I renamed it to de265.dll and now it works fine.
Thank you!
