XnView: MP 1.5.5 - 64 bit
OS: Linux - 64bit
The new rating filter visual functions for 1-5 and <=, >=, = just fine. However, selecting the empty star clears the filter rather than filtering by "unrated" (so = and empty star shows all ratings).
Effect: Cannot filter by unrated images.
1. Open a directory with some unrated and some rated images.
2. Set image rating filter operand to '='
3. Set image rating filter star to 0 (click empty star on left)
Actual behaviour (bug): filters by all images of any rating
Expected behaviour: filter to only unrated images
Thanks! Been using MP for years, love the software but this functionality seems to have broken between versions.
1.5.5: Filter by unrated does not work
Re: 1.5.5: Filter by unrated does not work
Note that using the Search function and selecting Rating > Equal To > Unrated also pulls up no results. If it's relevant, I have XMP sidecars enabled and ratings get dumped to there along with categories and other metadata.
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
