Viewer - properties - unify appearance
XnViewMP 1.5.5 64bit
Viewer - properties
test_img.zip
(5.05 KiB) Downloaded 45 times
Suggestion A
change vertical alignment to the 'top' for all sizable cells (see other suggestions)
Suggestion B
make cells sizable, so they can show multiline content and
maybe add 'Wrap text' option in context menu
  • EXIF tab
    - XPComment
  • ExifTool tab
    - File > Comment
    - EXIF > XP Comment
Suggestion C
stretch cells (of 2nd column) across, all the way to the right window border
  • Properties, ExifTool tabs
Suggestion D
horizontal scrollbar should not appear if there is no offscreen content
Related
Re: Viewer - properties - unify appearance
user0 wrote: Sun Mar 03, 2024 4:34 am Suggestion B
Like 'Embedded comment'?
xnview wrote: Sun Mar 10, 2024 2:39 pm
i would set goal like this:
  • minimum
    • like 'Embedded comment'
  • maximum
    • change "like 'Embedded comment'" to
      - [Suggestion C] cell is stretched to the dialog border AND
      - text is auto-cropped right at this border with '...' mark
    • add 'Wrap text' option (see pic)
      when enabled:
      - text is not auto-cropped, instead cell's height is increased automatically
user0 wrote: Sun Mar 10, 2024 5:45 pm
  • minimum
I've checked with Qt, but results are not good...
A,D - done
