It used to be possible rate images with stars and then filter them on the stars rating.
Now, I can only find "colored bubbles" in the filter, stars rating have disappeared.
How can I filter on stars rating ?
Is is possible to add them back to the filter menu ?
Many thanks
Filtering on stars - SOLVED
Re: Filtering on stars
I found the "Rating" in the Toolbar options.
Problem solved
Problem solved
