1.5.5.0.XvView MP - bug with video files
mquentin
Post by mquentin »
Subject: 1.5.5.0.XvView MP - bug with video files
XnView: MP 1.5.5 - 64 bit
OS: Windows 10 - 64bit
Program stop to run with video files
Effect: Program hangs: Program bug when I try to read or move video files: program stop du run, I had to close it (and I can only to do it whith the "report to windows")
I had not this problem previously, if I install "previous" XnView MP, I have still the problem
1. open a folder with image and video file
2. click on one image: ok
3. click on one video file: reading of video file begin
4. two second later, XnView stop to run
Same problem if
2. delete or add an image file. The order of all the files in the folder are moved (included video file)
3. XnView stop to run
Expected behaviour: possibility to rearrange all the files, including video files, as previously with XnView open and running
Thanks
Re: 1.5.5.0.XvView MP - bug with video files
you have crash on all video type? and always?
mquentin
Post by mquentin »
I tried with mp4, flv, mkv... same problem allways
no crash with avi
do you have sent dumps with crash dialog?
jadO
Post by jadO »
I can confirm this issue with version 1.5.5. Pictures and Avi do work. All other video files cause XnvieMP to crash.
jadO wrote: Tue Sep 19, 2023 1:09 pm I can confirm this issue with version 1.5.5. Pictures and Avi do work. All other video files cause XnvieMP to crash.
you had same crash in previous version? crash with mp4? could you change in xnview.ini debug=2, and send the logs?
mquentin
Post by mquentin »
xnview wrote: Tue Sep 19, 2023 6:24 am do you have sent dumps with crash dialog?
I've sent you the logs in DM. Thanks in advance for your help.
jadO
Post by jadO »
This bug has not been mentioned in the changelog of latest versions. But with version 1.6.1 it seems the bug not there anymore.
masterjp
Post by masterjp »
flv and mp4 files are video container for different video formats.
https://www.videohelp.com/software/MediaInfo
Maybe a tool like MediaInfo can help to analyse the content of the video file, fornat, etc.
FLV files are sometimes very special.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
mquentin
Post by mquentin »
jadO wrote: Thu Oct 19, 2023 3:40 pm This bug has not been mentioned in the changelog of latest versions. But with version 1.6.1 it seems the bug not there anymore.
I install this latest version 1.6.1.... same problem
masterjp wrote: Thu Oct 19, 2023 3:53 pm flv and mp4 files are video container for different video formats.
Thanks but unfortunatly the problem does not come from the video files, I have tried A LOT of them and in different formats. Each time the program crashes. But I use Xnview to sort folders which contain both images and videos inseparably.
What is unfortunate is that in olders versions (at least 3 or 4 previous versions), I did not have this problem.
I tried uninstalling Xnview to reinstall older versions but the problem seems rooted. Incompatibility with some Windows updates?
mquentin wrote: Sun Oct 22, 2023 12:31 pm
Please enable debug=2 in xnview.ini, and send me the logs when you try to play a video file
