Multiple Extensions for Hot Folders?
Sprawl2459
Post by Sprawl2459 »
Hi there!
I'm trying to get a hang of the Hot Folders option for Batch Convert, and for the life of me I can't figure out how use the Extensions field. Using just one, like png, works fine but how to separate multiple extension? I tried jpg,png, jpg|png, jpg png, [jpg] [png], but to no avail.
Thanks!
Re: Multiple Extensions for Hot Folders?
I haven't used Hot Folders recently, but does writing extensions from left to right with a space between them not work?
Sprawl2459
Thanks for your reply, but no, I tried that too (see my first post).
But maybe with the dots: .jpg .png ?
Otherwise, maybe a bug?
Sprawl2459
Good guesses I reckon, but I now tried .jpg .png, .jpg,.png, JPEG PNG, and JPEG,PNG. It doesn't work for me. : (
Is the Hot Folder option working for you with a single extension?
I've tied a quick test using XnConvert 1.98, and am not getting the expected result, but I would be cautious about drawing any conclusion from one quick test when there could be a simple explanation.
One possible unrelated bug or limitation is that the Convert button to launch processing is greyed out unless a file is loaded on the Input tab, seeminly not possible to set up Hot Folder operation in isolation??
Sprawl2459
Yes, if I only type png it works as intended. But I gotta add more formats.
I can confirm your second observation. One has to start the conversion of at least one file, for the Hot Folders operation to kick in. I would kinda expect once the Hot Folders checkmark is set either the Convert button gets un-grayed, or the Input list gets populated with files from the hot folder(s). But that's off-topic, for now. ; )
Earlier versions are available here if you have time to investigate either issue further.
Possibly a bug arising from the recent addition of recursion??
A possible temporary workaround, if needed, might be to use two program instances, either installed 'MP plus a ZIP, or two ZIP versions which I think it should be possible to configure to work independently. Or maybe neater, two XnConvert ZIP instances.
Sprawl2459
What earlier version would you suggest for a try-out?
I applaud your suggestion regarding using two instances of XnView MP. Very out of the box thinking. : ) But yeah, I don't need this feature THAT much. ; )
Sprawl2459 wrote: Thu Aug 10, 2023 5:53 pm What earlier version would you suggest for a try-out?
For XnView MP, I would suggest going back a fair number of versions due to the frequency of updates, while confirming that the functionality you need is supported; you could also look back through the change lists to see when something that might be relevant changed.
For XnConvert, a really neat utility nominally the same as 'MP Batch convert, but updates not synchronised, as updates are less frequent not so far, change lists also easier to scan through.
Moderator & Librarian
Sprawl2459
Hey, thanks for these links. I reckon they confirm it should work. But I still struggle finding the correct syntax using the Extensions field. It's nowhere mentioned in these links me thinks...
For me, XnView MP v1.5.3 @ Windows 10 Pro 22H2 works as expected:
  1. Go to ToolsBatch convert…InputHot folders…Add folder… and add something like X:\Test\Source\.
  2. Enter png jpg in the Extensions field and confirm with OK.
  3. Back in the Batch convert dialog, go to ActionsAdd action>Image and select Mirror.
  4. Go to OutputOutput and enter X:\Test\Destination\ in the folder field.
  5. Open File Explorer and copy test.png to X:\Test\Source\.
  6. Open File Explorer and copy test.jpg to X:\Test\Source\.
Sprawl2459
Hi, thanks for replying in such detail. : ) So I reckon the way I used the Extensions box wasn't the issue. I'll save the sequence you layed out. It works no problem now.
