Steps to reproduce:
1. Set Preferences/Settings > View > Title bar: {Filename With Ext}
2. Open XnViewMP browser mode.
3. Press "ENTER" to open an image in Viewer mode.
4. Title bar shows "/path/to/folder/" instead of "IMG_1234.JPG"
5. If you press LEFT/RIGHT in Viewer mode to previous/next image, then the Title Bar correctly displays "IMG_1234.JPG".
Environment:
XnViewMP 1.4.5
MacOS 12.6.5 Monterey
1.4.5 Title Bar does not show correct info initially
Re: 1.4.5 Title Bar does not show correct info initially
are you able to reproduce each time, i cant?
I do not see this bug anymore in XnViewMP 1.5.5 (on MacOS 12.6.5 Monterey). So I think this can be closed.
