Viewer - selection - ratio - add Fixed option
XnViewMP 1.8.2 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
there are 2 state indictors can be visible at the same time (eg Free and 1:1), which does not make much sense.
However, it can be improved by adding new 'Fixed' option, so the 1st group is Free/Fixed and the 2nd group contains all fixed ratios (similar to Crop panel).
  • improve selection ratio state options/indication
    • add new 'Fixed' ratio option
    • move 'Same as image' to the fixed ratios group
Related
Last bumped by user0 on Fri Jan 17, 2025 9:21 am.
