B3: Xjp2.dll - Doesn't like corruped Jpeg2000 streams (JP2)
BlindWanderer_
Post by BlindWanderer_ »
Incomplete JP2 files: Other older plugins handle incomplete files.
Steps to duplicate:
Start with a valid jp2 file (don't use the xnview beta version to create it)
Open the image in xnview beta to make sure it works.
Open the image in a hex editor and remove a couple hundered bytes off the end of the file.
Save the file and reopen in xnview.
Corruped JP2 files: Other older plugins handle partially corruped files.
Steps to duplicate:
Open the image in a hex editor and overwrite with a couple hundered bytes anywhere in the stream.
XnView 1.82 Beta3
BlindWanderer
Post by BlindWanderer »
very sorry forgot to say, the release is beta 3
BlindWanderer wrote:very sorry forgot to say, the release is beta 3
Could you send me a sample?
Xyzzy
Post by Xyzzy »
Hmm, I got this file:
http://www.phys.uni.torun.pl/~duch/Wykl ... 0/girl.jp2
In b3, xjp2.dll ver 1.82:
If I replace 500 bytes in the middle, picture is displayed OK (of course with some distortions).
If I cut 500 bytes from the end, XnView does not recognize it as an image. If filetype recognition is turned off, XnView displays "Format of the file could not be determined" when trying to view it. I don't know if it is OK.
In 1.80 with dll ver 1.80 the behaviour is identical.
So no confirmation.
X.
BlindWanderer-T
Post by BlindWanderer-T »
Sure...
Normal
Truncated
Zero'd blocks
ehh my forum registrations is taking forever ~_~
BlindWanderer-T
And this bug is still present in RC3.
The issue is that there are missing blocks (or is the word i'm looking for frames?) from the jp2 streams. Or that the boundries have become corruped.
The corrupted files I deal with, the amout of data corruped is in 1000 byte blocks. Where it's offset by 600. The corruption starts at N600 where N is an integer.
