Shift[ shortcut stored as Shift{, making it unusable
esv
Post by esv »
I'd like to use Shift+[, however, in the Interface→Shortcuts when I use this combo, it gets recorded as shifted twice, i.e., as Shift+{ instead of Shift+[
This makes the shortcut unusable as you can't enter the double-shifted Shift+{
The same thing happens with Shift+123..., gets recorded as Shift+!@#, etc
XnView MP MacOSX
Version 1.4.3 64bits (Feb 25 2023)
Libformat version 7.138
Re: Shift[ shortcut stored as Shift{, making it unusable
yes but it works here (french keyboard). Which layout?
esv
Post by esv »
English US layout
But it seems I was wrong about P, just tried it again it a couple of layouts and alpha-keys seem to work fine, so maybe it's only symbols that are special
Tried with 123... and that also fails with !@#...
