Colors look disastrous
WS007
Post by WS007 »
I have a M1 MacBook Pro that I use with a BenQ SW270c as second monitor. For editing photos and videos I use LR classic, Photoshop and DaVinci resolve. I use XNView just for arranging my slides (photos and videos) for slideshows in the right order and renaming them, so that they stay in this order for presentation...
=> This works, but the colors look highly oversaturated (on both displays) and completely unnatural.
What can I do to fix this problem?
Wolfgang
Re: Colors look disastrous
do you use Settings>General>ICC?
WS007
Post by WS007 »
Hi Pierre,
Yes, I use it. I tried already several profiles, but the appearance does not change (also when I do not use ICC)...
When I shift the image from the BenQ monitor to the retina monitor of the MacBook, the oversaturation is better, but still exists...
Wolfgang
could you send me the image file and profil?
WS007
Post by WS007 »
Hi Pierre,
The file is too large, but here I have put it into dropbox, together with a color profile: https://www.dropbox.com/scl/fo/row61o8g ... 6rgv57kyje
=> Bur as I said it does not make a difference, whether I use this profile or nothing...
Wolfgang
with this profile it's normal, it's sRGB profile, and the image is in sRGB so no conversion. Could you send me screenshots in XnView MP & other app?
WS007
Post by WS007 »
Hi Pierre,
Thank you for taking care. I have put two screenshots in dropbox (https://www.dropbox.com/scl/fo/row61o8g ... 6rgv57kyje): "Preview" displayed with Preview and XNView displayed with XNView...
I admit the red is demanding, but it looks much better when the file is viewed via Preview and completely unnatural when viewed via XNView...
Wolfgang
could you send me the same file as screenshot?
WS007
Post by WS007 »
Hi Pierre,
I have put the file in the same dropbox now. It is Ägypten_2022_11_Mangrove_0055.jpg...
Thanks for taking care, Wolfgang
on the screen of M1, do you have same problem? with or without ICC doesn't change anything, right?
WS007
Post by WS007 »
Yes, on the screen of M1 MBpro the files also look different (XNView beeing oversaturated and unnatural)...
WS007 wrote: Thu Mar 23, 2023 1:16 pm Yes, on the screen of M1 MBpro the files also look different (XNView beeing oversaturated and unnatural)...
Please check next version, i've changed the way that icc engine works...
