select paste position
6. can you add an option for merging pictures on selectable border. e.g. i have two pictures with same resolution and i would like to make it only one picture, so i tell xnview to add the picture in clipboard to the right of the viewed picture. or add it at the top. or left...
Re: select paste position
You can perhaps use 'Panorama/Merge pictures'Anonymous wrote:6. can you add an option for merging pictures on selectable border. e.g. i have two pictures with same resolution and i would like to make it only one picture, so i tell xnview to add the picture in clipboard to the right of the viewed picture. or add it at the top. or left...
