Close all tabs when quiting and may be work in one tab
avmaksimov
Post by avmaksimov »
It is possible to close all tabs when quitting? I don't wan't to close tabs manually.
And is it possible to work with one tab? Or may be two: for browser and view? Better I would open in a new tab when I need to.
Re: Close all tabs when quiting and may be work in one tab
avmaksimov wrote: Thu Feb 23, 2023 12:50 pm It is possible to close all tabs when quitting? I don't wan't to close tabs manually.
without confirmation of saving?
yes 'Settings>Interface - Tabs'
avmaksimov
xnview wrote: Sun Feb 26, 2023 1:45 pm
Thank you. Yes. I understand the risk of it. As it usual for orthodox file manager (like Total Commander / Double Commander / Unreal Commander and so on).
If I need I wouldn't close the XnView. Or may in future you can add locked tabs. But for me enough option not to restore previous tabs. But may be the last one is good.
avmaksimov wrote: Sun Feb 26, 2023 2:14 pm If I need I wouldn't close the XnView. Or may in future you can add locked tabs. But for me enough option not to restore previous tabs. But may be the last one is good.
you would like an option to not restore tabs from last instance?
avmaksimov
xnview wrote: Sun Feb 26, 2023 2:27 pm
Yes. It would be great for me if it's possible.
'Settings>General>Save session...'
avmaksimov
xnview wrote: Mon Feb 27, 2023 9:15 am 'Settings>General>Save session...'
Thank you very much! And BTW may be there is a way to move Menu above the tabs and toolbar? I mean: menu, toolbar and after Tabs? As it usually in another program?
And I suggest to hide intergration in Linux if it doesn't work / not applicable.
Thank you for your attention.
