TAB behavoir / merging / more undo / other..
kris
Post by kris »
hi,
1. I tried for like half an hour to find an option to turn on the multiple tab loading. now it seems, that you can only open multiple pictures in multiple tabs by first choosing the thumbnails -> RMB -> open all selected.
as an tabbed-browser-user this is a wicked behavior. would like to have for each doubleclicked picture a separate tab, and not using only one tab by doublecklicking a thumb and closing all other tabs?!
2. the .ini is not saved in my xnview-folder, but in the windows-folder. not very good for backupping.
3. would like more options to be available with the view-toolbar like resize i´m using very often.
4. possible to make multiple undo´s?
5. the fit to window seems to be not very intelligent. if the fit window to picture is chosen, it should of course only do that, when the picture is smaller than the desktop resolution, otherwise the larger picture (option) should fit the window if set to this.
6. can you add an option for merging pictures on selectable border. e.g. i have two pictures with same resolution and i would like to make it only one picture, so i tell xnview to add the picture in clipboard to the right of the viewed picture. or add it at the top. or left...
7. last but not least i would like to paste a copied part of a picture to the new cursor position rather than have to draw a rectangle and the copied part is resized when pasted into it.
thx for listening ;)
No---
:) Hi !
1. This is not true; you can always get one tab per file, as well from a thumbnail as from any pic file open from the "File" menu (or the similar button)
2. Options >> Install remove the nick for this location; with not any stated location, the INI is saved in the folder of the programme, that I do for years.
Sorry, I willn't reply further, according with the forum rules, you might split you message (one per topic, please), and use the Search
:mrgreen: KR
Re: TAB behavoir / merging / more undo / other..
Hi kris,
welcome to the XnView forum and thank you for your post. As Clo has pointed out, most of your questions have been posed before. Please use the forum search ("Search" menu item at top of this page) to find the appropriate infos. If you do not succeed, please post individual topics with one question, not one topic with many questions.
Thank you. Helmut
