How to modify directory background color?
gacg
Post by gacg »
Good morning
How to modify the background color of the thumbnails concerning the directories, I know how to do for the files but I did not find for the directories.
Thanks for your help.
Re: How to modify directory background color?
which background color?
gacg
Post by gacg »
the thumbnails representing the subdirectories have a yellow background that I would like to change.
THANKS
in xnview.ini, you'll find folderColor1-folderColor5
gacg
Post by gacg »
Oh ok thank you very much
gacg
Post by gacg »
And thank you for this great photo viewer.
Efficient and very complete.
gacg
Post by gacg »
"in xnview.ini, you'll find folderColor1-folderColor5"
Really sorry for my lack of precision but I am under macos.
you can find the xnview.ini by using Settings>Integration - Paths - 'Open config files location'
gacg
Post by gacg »
Sorry, I modified the xnview.ini file accordingly, the new values are well saved but it does not change the background colors of the subdirectories.
ex:
folderColor1=6 25 79
folderColor2=6 25 79
folderColor3=6 25 79
folderColor4=6 25 79
folderColor5=6 25 79
you need to select subfolders, and View>Rebuild thumbnails
gacg
Post by gacg »
the xnview.ini file is reset each time the application is restarted.
gacg
Post by gacg »
It's all good now.
Thanks for your patience and help.
