Importing files from the SD card from my camera
doobs
Post by doobs »
Hi all,
I've done a little spelunking around and I'm just not smart enough to figure this out.
Currently I use an old version of LightRoom to ingest files from my camera's sd card. I use Fuji exclusively BTW. I also shoot saving both jpg's and raf files.
It's a three step process at present, ingest and then rename the file based upon the Caption entered, and then rename the folder.
I'd like to use XnView MP to replace LightRoom in this process. It's the only thing I use LightRoom for. All my post processing is done in Capture One.
1) Assign a Caption on the images to be imported
2) Import the images to my NAS box in a folder nameds thusly -> YYYY/mmdd-{Caption}
3) Rename them YYYYmmdd-{Caption}.xxx.jpg/raf -> where xxx is a sequence number.
4) Extra points are awarded for renaming the jpg/raf pairs correctly.
Is this possible in a single or maybe two steps with XnView MP?
Thank you
chris
doobs
Re: Importing files from the SD card from my camera
Post by doobs »
Ok then.
I'll take it by the lack of response that what I want to do isn't possible in XnView MP.
Cheers,
currently not possible to edit IPTC, but i'll add a way to set an IPTC template
