What are the system requirements for XnShell Extension (XnShellEx) 4.16?
- No system requirements are mentioned on the XnShellEx product page. It just has Windows 32-bit and 64-bit downloads.
- I do not see any requirements or Windows versions mentioned in this forum topic either.
Which versions of Windows are supported for XnShell 4.16?
- It works for me on Windows 10 and Windows 11.
- Is Windows 8.1 still supported? If not, what is the last version of XnShellEx that will work on Windows 8.1? Please, provide a download link for that older version.
Are there any other system requirements besides the supported Windows versions?
XnShell Extension is a wonderful add-on for XnView. Thank you.
XnShell Extension 4.16 - System Requirements
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
** XnView ROCKS **
Re: XnShell Extension 4.16 - System Requirements
No special requirementsSeaMaiden wrote: Mon Jan 30, 2023 6:05 am - No system requirements are mentioned on the XnShellEx product page. It just has Windows 32-bit and 64-bit downloads.
I think that it works on Windows 7/8- It works for me on Windows 10 and Windows 11.
If earlier Windows versions aren't in fact supported, you can download earlier XnShell Extension versions here.
Thanks, everyone, for that information.
** XnView ROCKS **
** XnView ROCKS **
