1.4.0 Canvas resize ignores saved percentage
Zeus
Post by Zeus »
XnView MP MacOSX
Version 1.4.0 64bits (Dec 13 2022)
macOS 13.0.1
Selecting a preset for the Batch Convert doesn't apply the percentages saved in the XBS file for Canvas resize width and height.
When I select a preset with the Canvas resize as below, XnViewMP is always reverting to 0.00% instead of 117.24%
<Canvas_resize mode="0" width="117.24" height="117.24" unit="1" relative="false" ratio="true" orientation="false" color="#ffffff" colorFlag="true" colorAt="0" alpha="255" position="4"/>
Zeus
Re: 1.4.0 Canvas resize ignores saved percentage
Post by Zeus »
After some testing, it seems this bug is reproduced when decimal digits are used in the percentage.
  • Tools > Batch convert
  • Actions Tab > Add action > Image > Canvas resize
  • Set Mode to "Normal"
  • Set Unit to "percent"
  • Set Width and Height to "100.10%"
  • Save preset (test preset)
  • Select any other preset from the Preset dropdown, and select back the test preset
Expected behaviour: Width and Height are set to the saved percentage "100.10%"
Effect: Width and Height are set to "0.00%" and the saved XBS looks like the below with "width2", "width3"...
<?xml version="1.0" encoding="UTF-8"?><XnView_script version="1.0" name="1.4.0 Canvas resize testing">
    <Canvas_resize mode="0" width="800" height="600" width2="100.1" height2="100.1" width3="1" height3="1" unit="1" relative="false" ratio="true" orientation="false" color="#ffffff" colorFlag="true" colorAt="0" alpha="255" position="4"/>
    <Output folder="" filename="{Filename}" case="0" startIndex="1" format="">
        <Options overwrite="0" orgDate="false" keepMeta="true" keepICC="false" keepFolder="false" keepParentFolder="false" keepExtension="false" delOrg="false" multipage="false" allPages="false" openExplorer="false" beep="true" openBrowser="false" clearItems="false"/>
        <JPEG quality="85" progressive="false" optimizeHuffman="true" rebuildThumb="true" orgQuality="false" DCTMethod="0" subSampling="0" smoothFactor="0"/>
        <TGA compress="false" bottomUp="false"/>
        <TIFF compress="0" quality="80" compressBW="0" oneStrip="false"/>
        <BMP compress="false" hdrOS2="false"/>
        <PNG level="6" interlaced="false" filter="0"/>
        <GIF interlaced="false" hdr87a="false"/>
        <PCX compress="false"/>
        <WEBP method="0" quality="80" filesize="128" compress="4" strength="60" sharpness="0" preset="0"/>
        <GUETZLI/>
        <JP2 mode="0" quality="80" ratio="4" fileSize="100"/>
        <PDF compress="0" compressGrey="0" compressBW="0" quality="80"/>
        <JXR quality="80" colorFormat="0" filter="0"/>
        <JPEGXL quality="80" lossless="true" effort="7"/>
        <HEIC quality="80"/>
        <FORMATS_SETTINGS keepEXIF="true" keepICC="true" keepIPTC="true" keepXMP="true"/>
    </Output>
</XnView_script>
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
Zeus
Post by Zeus »
1.4.1 installed
OLD XBS
Still, when I select the same old preset (created with the width and height containing decimals), the width and height fields are set to 0.00%:
NEW XBS
When I recreate the preset in 1.4.1 and use it, the width and height fields are set correctly with the decimals:
<Canvas_resize mode="0" width="0" height="0" width2="117.24" height2="117.24" width3="0" height3="0" unit="1" relative="false" ratio="true" orientation="false" color="#ffffff" colorFlag="true" colorAt="0" alpha="255" position="4"/>
