1.4.0 - Selected files are not highlighted in browser [Solved]
pkvaipc4j0
Post by pkvaipc4j0 »
Selected files are not highlighted in browser mode.
It was highlighted in 1.3.1.
Below are screenshots of selecting all files with ctrl-A.
- XnView MP 1.4.0
- XnView MP 1.3.1.
ckit
Re: 1.4.0 - Selected files are not highlighted in browser.
Post by ckit »
Sorry, I'm can't confirm
deil
Post by deil »
For me they are kinda highlighted, but only the last selected file is highlighted with blue color. Other files are "highlighted" with white color, and it's really hard to see. On the first screenshot I have 3 files in the middle selected.
Another bug, probably related to this one. If you have some selected files, and then alt+tab back and forth, and click somewhere to remove selection, some parts of blue selection outline are still visible. 2nd screenshot, there are blue vertical lines around 3rd and 4th images.
XnView MP 1.4.0 x64, Windows 10 22H2
ckit
Post by ckit »
Ok, I didn't have "Thumbnails + Labels" ON, I prefer "Thumbnails + Filenames" most of the time
First bug, still can't reproduce but the Second bug, I can see a 1 pixel displacement at the bottom of the "Thumbnail Label" which goes away when clicked upon. Could be a video driver thing too
Toxxyed
Post by Toxxyed »
pkvaipc4j0 wrote: Tue Dec 20, 2022 12:28 am Selected files are not highlighted in browser mode.
- XnView MP 1.4.0
- XnView MP 1.3.1.
Hello, this is also the case here, selected files are not marked in blue but in white. The marked files are so very difficult to recognize.
In addition, the program starts in English and not, as with all previous versions, in German. I can't change it manually.
XnViewMP, 1.4.0
Lib format version 7.132
macOS Ventura 13.1
M1 Pro
I can't reproduce, which theme do you use? could you send me the xnview.ini?
deil wrote: Tue Dec 20, 2022 3:04 am For me they are kinda highlighted, but only the last selected file is highlighted with blue color. Other files are "highlighted" with white color, and it's really hard to see. On the first screenshot I have 3 files in the middle selected.
which theme do you use? Could you send me your xnview.ini?
Toxxyed wrote: Tue Dec 20, 2022 9:52 am Hello, this is also the case here, selected files are not marked in blue but in white. The marked files are so very difficult to recognize.
do you use light or dark macos theme? and in XnView which theme?
You can't change in settings>General - Language?
pkvaipc4j0
xnview wrote: Fri Dec 23, 2022 9:40 am
xnview.ini is here.
xnview.zip
(8.04 KiB) Downloaded 54 times
Toxxyed
Post by Toxxyed »
xnview wrote: Fri Dec 23, 2022 9:44 am
I use the light macOS theme. And there the difference between marked and unmarked files is hardly noticeable.
I set the dark macOS theme to test. With this, the marked files are clearly visible, not in blue, but in a dark gray in contrast to the unmarked files, which are shown in light gray.
I haven't found a way to change the theme within XnView yet. XnView is light on macOS light theme setting and dark on macOS dark theme setting.
[/quote]
That was my mistake with the language, sorry. While searching for a solution for the marked files, I overlooked this setting option. This option was set to "System Settings", which is German. XnView MP did not take care of this when installing the new version. But now I can set it manually.
Thank you for your efforts and a "Merry Christmas" to all
toyotadesigner
Post by toyotadesigner »
I just ran into the same problem:
I can no longer select consecutive files with SHIFT+LEFT MOUSE CLICK, and I no longer can select more than one file with CMD+LEFT MOUSE CLICK.
macOS Catalina version 10.15.7 (19H2026), XNVIEW 9.1.4
Standard installation
Standard color scheme (silver)
No plug-ins or any other modifications
The previous version
XnView MP MacOSX Version 1.3.1 64bits (Oct 11 2022)
Libformat version 7.126
worked flawlessly
I did not modify or change any setting for years…
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
Toxxyed
Post by Toxxyed »
xnview wrote: Mon Jan 16, 2023 12:35 pm This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
Have version 1.4.1 installed.
The correct language was set automatically.
Marked images are again highlighted in blue.
Thanks for the fix :D
pkvaipc4j0
Checked with 1.4.2.
Thanks for the fix.
