This machine https://www.elgato.com/en/stream-deck-mk2
allows you to assign common used things to buttons. It would be great to have more controls from xmp that can be assigned.
1) I have a bunch of scripts under ctrl-u, I'd like to assign each to a key
2) changing filters - jpg only, vs all images
3) changing tabs
It could be a lot, but a way to assign ctr/shft/alt/key/Fkey combos to actions means we can use this tool for XMP.
Also each menu item should have a unique underline access key.
More shortcuts?
