I upgraded to v1.40 on a Windows box, and it no longer honors the dark theme set in the OS.
I went through all the settings in the Settings UI, and couldn't find a solution.
After a bit more poking around, I found, View -> Theme, which fixes the issue (almost).
So for those with the same issue, hopefully this posting will help your weary bat-retinas.
I say "almost" because with the included dark theme, menuitem strings become hard to see when the associated menuitem is hovered with the cursor. Perhaps this can be fixed in the next version?
Holy Burning Retinas Batman!
Re: Holy Burning Retinas Batman!
do you use windows dark theme & XnView default theme? could you post screenshots?
