- This thread is related to an issue posted by a French-speaking member on the French forum.
• In brief :
- The user Enoch reads large images in “View” as 1:1 scale and can't use the option «Fit image to window» because they are pages of some comics, and fit to window should result in too small images, quite uncomfortable to read the balloon-captions easily…
- The issue is that each next large image (page of the comic) comes on the screen as centred, so the top-display needs a scroll to follow the story, that is rather irritating…:(
- Indeed, same problem using “Full screen” from “View”.
- AFAIK, there is not any known option to fix this. Maybe someone does know some workaround (else than «Fit image to window») ?
- Whether nothing could be found, this should request a couple of options, let's say as extra INI-entries since it's a bit special like :
{ Aside : Thanks to Paul-"Ouistiti" for his tests, searches and ideas about that issue }DisplayLargeAtHeight = (flag)
¤ Flags : 0 —> Centred (default) ¦ 1—> from Top ¦ 2 —> from Bottom
DisplayLargeAtWidth = (flag)
¤ Flags : 0 —> Centred (default) ¦ 1 —> from Left ¦ 2 —> from Right
- All feedback welcome, thanks !
