Allow using template language in Info panel
esv
Post by esv »
You have this awesome UI feature that allows using a template language to customize tooltips in the Browser (as well as thumbnail labels)/info overlay in the Viewer
However, I often need the more detailed/comprehensive default Info/Properties dialog in the Browser to get some info without the need to mouseover to see a more beautiful tooltip, but then the default wastes way too much space
most of this info could fit in a couple of lines (not fully compatible pics, just an illustration)!
So I'd like to be able to fully customize those Info dialog panels as well. However, not to lose their comprehensive nature where they include a lot of fields which I don't want to recreate from scratch (or at least not right away, that's too much work), I'd like to be able to simply have a list of all the default fields, but then be able to toggle some of them off, reorder them, and then add my custom fields that would use the template with a different format.
Re: Allow using template language in Info panel
yes in my TODO list
