Template: hide symbols if some tag value is blank
esv
Post by esv »
For templates (e.g., for customizing tooltips) I'd like to be able to hide some separators if the values they separate are empty
For example, currently
{Tag status} | {Rating} | {Color label}
shows as
when all fields as empty
I'd like to "tie" the "|" symbols to the previous values and don't show them if those values are blank, so for example, if I enter the following mock template
{Tag status}{≠∅" | "}{Rating}{≠∅" | "}{Color label}
(where {≠∅" | "} means "if the previous tag is not empty, print this string)
I'd get this nice empty field (without any newlines as well, though that would require some other templating feature)
Re: Template: hide symbols if some tag value is blank
Do you have tried
(({Tag status} | ))(({Rating} | ))(({Color label}))
esv
Post by esv »
No I haven't, I didn't know it existed, where is this documented?
so from testing this
t{Tag status} | r{Rating} | c{Color label}
((t{Tag status} | ))((r{Rating} | ))((c{Color label}))
get
t[] | r | c
t[] |
Good news is that the Rating/Color tags seem to disappear, but the status remains
Also, is there a similar trick for the newline char? Can I completely remove the line if it's empty, something like this doesn't seem to work, I always get a newline
(((((r{Rating} | ))((c{Color label}))<br>))
