Setting DPI for HEIC files does not appear to work.
swainstm
Post by swainstm »
I have beening using XnConvert to convert JPG to reduce size but also set DPI so the reduced size pastes into Word documents without need to adjust size. I am experimenting with HEIC. But when I convert to HEIC with the same action to change the DPI, the DPI does not change in the output HEIC file. Is this a bug, or not possible, or am I missing something?
I was using 1.95. But upgrade to 1.96 and still has same issue.
Thanks heaps.
Re: Setting DPI for HEIC files does not appear to work.
currently i have no way to write the dpi in heic format
