REQ: Some name changes
Locked
Xyzzy
Post by Xyzzy »
Hello!
Rename:
View>File list to fe. File sequence, not to mistake it for file list in Browser window. Or the other way, rename Browser>File list to File panel or smth. similar)
View>File list>Cache to fe. Buffer (and also Keep current image in buffer), not to mistake it for thumbnail cache
Folder tabs just to Tabs (they are surely not _folder_ tabs).
X.
Olivier_G
Post by Olivier_G »
I support View>File sequence and its Buffer.
I also prefer "Tabs" to "Folder tabs". Wouldn't "Windows tabs" be correct as well?
Olivier
Xyzzy
Post by Xyzzy »
Window tabs are OK (I guess it should be Window, not Windows, because every tab refers to one Window, but I think native speaker has to verify it).
X.
Danny
Post by Danny »
I agree that "folder tabs" is just wrong. I don't care if you call it window tabs or just tabs though.
Danny wrote:I agree that "folder tabs" is just wrong. I don't care if you call it window tabs or just tabs though.
So everyone agree with 'Tabs'
ckv
Post by ckv »
xnview wrote:So everyone agree with 'Tabs'
Oh me me. I agree. I think that everybody will understand what tabs the name "Tabs" mean :)
ckit
Post by ckit »
I agree with "Tabs"
Dreamer
Post by Dreamer »
ckit wrote:I agree with "Tabs"
Me too.
ckit
Post by ckit »
Changed in Beta 3.
marsh
Re: REQ: Some name changes
Post by marsh »
Xyzzy wrote:Hello!
Rename:
X.
Using different names for caches is helpful for forum conversation at least.
Locked
