Color labels are disappearing for me
nucine
Post by nucine »
Color labels are disappearing for me. I use them with photos that are on external drives. When after some time I reconnect the disk the labels have disappeared.
It didn't happen before. I've been using this system for years and no problems. This problem has been happening to me for a month or so.
XnView MP MacOSX
Version 1.3.1 64bits (Oct 11 2022)
Libformat version 7.126
Re: Color labels are disappearing for me
do you write color labels in metadata of file?
nucine
Post by nucine »
No, I just select the color in the context menu
but what do you have in settings>Metadata?
nucine
Post by nucine »
Export color label in XMP metada: not cheked
Maybe it will be fixed if I set it checked?
so color label is only saved in database, the folder of external drive has not changed? Do you see it in Settings>Catalog?
nucine
Post by nucine »
The disk has not changed. And yes, it's in Settings>Catalog
is it possible to send me your .db to check content?
nucine
Post by nucine »
Yes. Where can I find it?
nucine wrote: Fri Oct 28, 2022 12:30 pm Yes. Where can I find it?
Settings>Integration>Paths - open catalog location
waverly
Post by waverly »
There is definitely a bug where the database is losing data. :(
I just noticed that many image ratings, which I assigned to files over several years, disappeared in Version 1.3.1 64bits (Oct 11 2022).
I have (mostly?) worked around it by importing a backup database from August. However I probably lost the last 2 months' worth of file ratings.
It seems (95% sure) that "Categories" data was not lost. Only "Ratings" data was lost.
(Unfortunately I cannot share my current database and known-good August backup database because the images and image data are private.)
you have lost rating on which file format?
nucine
Post by nucine »
For my part I have stopped using the color classification and now I use the Album classification, and in this way I am not having problems
