Please, don't post bugs or requests in this topic!
You can download XnView MP 1.3.1 here:
Windows x32 ZIP version SHA256: 2031DCA62BA1632F9E869EA7A9A4B44C3D623A6ECA1D162311A78A28FF87F727
Windows x32 SETUP version SHA256: BCBE5B403A3A64C54180EE2CEC71D555055D68CF3BD618032FE7E61E8389D34A
Windows x64 ZIP version SHA256: 16FD12593E8CFC01672CF8578F0B443098526829D93EAD3A75E029AA9F880B52
Windows x64 SETUP version SHA256: 2C272AB3BFF4E10F12E2A1644BE5526EBF98817F76762F5305EB8400EDB25C3B
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: F3A204F614E25615E4FAC6FFC379A19889065715CE0AD71F1340C77DBF9EB8EF
Linux x64 TGZ version SHA256: 892784F914C2C1DF8C47772EFFEBF8C4978E3C732E4936D7A4AEA04A0BF133E1
Linux x64 DEB version SHA256: 00979F01020036F6BF66FF496BDC460BA22A9B2E319B25CEB2891F4FD9BCAB9C
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.3.1:
2466: [New] Convert: File size info
2462: [New] Convert: Ratio pad - http://newsgroup.xnview.com/viewtopic.php?t=38790
2440: [New] JPEGXL 0.70
2437: [New] LibHEIF 1.13.0
2433: [New] Paint: Position for image watermark
2432: [New] Convert: Blurred frame - http://newsgroup.xnview.com/viewtopic.php?t=43835
2431: [New] Convert: Color at in Canvas resize - http://newsgroup.xnview.com/viewtopic.php?t=43750
2465: [Bug] Rating not applied correctly - http://newsgroup.xnview.com/viewtopic.php?t=44001
2464: [Bug] Settings ui - http://newsgroup.xnview.com/viewtopic.php?t=44006
2463: [Bug] Settings - http://newsgroup.xnview.com/viewtopic.php?t=44005
2461: [Bug] Video crash - http://newsgroup.xnview.com/viewtopic.php?t=43969
2460: [Bug] Return key does not work after 'add text' closed - http://newsgroup.xnview.com/viewtopic.php?t=44000
2459: [Bug] Menu entries not disabled on Empty tab - http://newsgroup.xnview.com/viewtopic.php?t=44015
2458: [Bug] Wallpaper dialog: default color - http://newsgroup.xnview.com/viewtopic.php?t=43998
2457: [Bug] Crash when adding keyword & no files selected (Category filter)
2456: [Bug] 'Edit XMP' doesn't change rating in catalog - http://newsgroup.xnview.com/viewtopic.php?t=43898
2455: [Bug] Video playing doesn't update progress bar - http://newsgroup.xnview.com/viewtopic.php?t=43985
2454: [Bug] Rotate color default value - http://newsgroup.xnview.com/viewtopic.php?t=43972
2453: [Bug] Crash with large JPEG XMP data
2452: [Bug] Strange behavior when extensions list is empty in 'Custom filter' - http://newsgroup.xnview.com/viewtopic.php?t=43907
2451: [Bug] Resize: 'load default values' - http://newsgroup.xnview.com/viewtopic.php?t=43955
2450: [Bug] Filter dialog ui - http://newsgroup.xnview.com/viewtopic.php?t=43942
2449: [Bug] 'Remove alpha channel' always enabled - http://newsgroup.xnview.com/viewtopic.php?t=43939
2448: [Bug] Language settings ui - http://newsgroup.xnview.com/viewtopic.php?t=43936
2447: [Bug] JPEG lossless rotation & long filename - http://newsgroup.xnview.com/viewtopic.php?t=43913
2446: [Bug] Most used format on saving - http://newsgroup.xnview.com/viewtopic.php?t=43916
2445: [Bug] Lossless HEIC - http://newsgroup.xnview.com/viewtopic.php?t=43911
2444: [Bug] JPEGXL lossless - http://newsgroup.xnview.com/viewtopic.php?t=43925
2443: [Bug] JXL/AVIF in archive can't be loaded - http://newsgroup.xnview.com/viewtopic.php?t=43903
2442: [Bug] Write settings dialog margin - http://newsgroup.xnview.com/viewtopic.php?t=43918
2441: [Bug] Capture: save filename - http://newsgroup.xnview.com/viewtopic.php?t=43456
2439: [Bug] Mac: Wheel problem for previous/next file - http://newsgroup.xnview.com/viewtopic.php?t=43793
2438: [Bug] No lossless backup for .jpeg - http://newsgroup.xnview.com/viewtopic.php?t=43879
2436: [Bug] Grid & subdivisions > spacing - http://newsgroup.xnview.com/viewtopic.php?t=43890
2435: [Bug] Crash when cleaning embedded comment
2434: [Bug] Convert: Resize by longest-shortest side & percent - http://newsgroup.xnview.com/viewtopic.php?t=43866
Changelog 1.3.0:
2430: [New] zimg 3.0.4
2429: [New] OpenJPEG 2.5.0
2428: [New] LibWebP 1.2.4
2427: [Bug] Crash on video file - http://newsgroup.xnview.com/viewtopic.php?t=43788
2426: [Bug] WebP for Thumbnail cache & RGBA thumbnail - http://newsgroup.xnview.com/viewtopic.php?t=43745
2425: [Bug] Video & Hdpi screen - http://newsgroup.xnview.com/viewtopic.php?t=43718
2424: [Bug] CVE by Xu Peng from UCAS (jpeg+pcx)
2423: [Bug] Capture: window width - http://newsgroup.xnview.com/viewtopic.php?t=43787
2422: [Bug] EXIF date not shown on some JPEG - http://newsgroup.xnview.com/viewtopic.php?t=43778
2421: [Bug] Resize: Longest/shortest not restored correctly - http://newsgroup.xnview.com/viewtopic.php?t=43738
2420: [Bug] Files from archive can't be opened in detail mode - http://newsgroup.xnview.com/viewtopic.php?t=43421
2419: [Bug] Double click on video file - http://newsgroup.xnview.com/viewtopic.php?t=43759
2418: [Bug] Archive browsing no more possible - http://newsgroup.xnview.com/viewtopic.php?t=43772
Changelog 1.2.0:
2415: [New] Libarchive 3.6.1
2411: [New] Convert: files in NConvert exported bat - http://newsgroup.xnview.com/viewtopic.php?t=43599
2406: [New] XMP Acdsee face region fields
2417: [Bug] AV1 video file thumbnailing
2416: [Bug] Icons in archive file - http://newsgroup.xnview.com/viewtopic.php?t=43725
2414: [Bug] Grey tiff 16 bits - http://newsgroup.xnview.com/viewtopic.php?t=43733
2396: [Bug] When saving, cancel in Write settings must not save - http://newsgroup.xnview.com/viewtopic.php?t=43555
2413: [Bug] Slideshow: Filename in sld with = char - http://newsgroup.xnview.com/viewtopic.php?t=43706
2412: [Bug] Grid not correctly restored - http://newsgroup.xnview.com/viewtopic.php?t=43715
2410: [Bug] Search: Category parent always selected & 'apply parent...' - http://newsgroup.xnview.com/viewtopic.php?t=43682
2409: [Bug] Suggested categories & 'apply to parent' - http://newsgroup.xnview.com/viewtopic.php?t=43698
2408: [Bug] Screen capture filename - http://newsgroup.xnview.com/viewtopic.php?t=43456
2407: [Bug] Statusbar 'file date' does not match settings - http://newsgroup.xnview.com/viewtopic.php?t=43701
Changelog 1.1.0:
2405: [New] MDK SDK instead of QtAV for video support
2374: [New] Edit IPTC/XMP: library
2392: [New] 'Save frame as' http://newsgroup.xnview.com/viewtopic.php?t=43526
2389: [New] Capture: Output folder - http://newsgroup.xnview.com/viewtopic.php?t=43456
2404: [Bug] GEM IMG crash - CVE Thanks to Danis Jiang
2403: [Bug] Abort in Search dialog - http://newsgroup.xnview.com/viewtopic.php?t=43657
2402: [Bug] If an error occurs when saving, no message
2401: [Bug] Bad mouse cursor in crop - http://newsgroup.xnview.com/viewtopic.php?t=43516
2400: [Bug] 'Show grid' not always restored - http://newsgroup.xnview.com/viewtopic.php?t=43610
2399: [Bug] Lock zoom not kept - http://newsgroup.xnview.com/viewtopic.php?t=43602
2398: [Bug] Contact sheet: size not restored correctly - http://newsgroup.xnview.com/viewtopic.php?t=43619
2397: [Bug] Acquire into: ISO date - http://newsgroup.xnview.com/viewtopic.php?t=43533
2395: [Bug] Edit comment: 'Write all' must close dialog - http://newsgroup.xnview.com/viewtopic.php?t=43615
2394: [Bug] Mac: Slideshow - when choosing color, dialog go to background - http://newsgroup.xnview.com/viewtopic.php?t=43575
2393: [Bug] White balance preset - http://newsgroup.xnview.com/viewtopic.php?t=43536
2391: [Bug] Wrong video orientation - http://newsgroup.xnview.com/viewtopic.php?t=39439
2390: [Bug] 'Update files from catalog' doesn't use settings - http://newsgroup.xnview.com/viewtopic.php?t=43489
2388: [Bug] Settings>Info - 'always in fullscreen' unchecked - http://newsgroup.xnview.com/viewtopic.php?t=43509
2387: [Bug] TTF thumbnail crash - http://newsgroup.xnview.com/viewtopic.php?t=39404
2386: [Bug] Export & Icc profile - http://newsgroup.xnview.com/viewtopic.php?t=43506
2385: [Bug] 'Convert to 256' shuffles colormap - http://newsgroup.xnview.com/viewtopic.php?t=43513
2384: [Bug] JPEGXL lossless output file size - http://newsgroup.xnview.com/viewtopic.php?t=43479
2383: [Bug] Batch convert: Film simulation parameters - http://newsgroup.xnview.com/viewtopic.php?t=43508
2382: [Bug] Edit mode: Bad file information in titlebar - http://newsgroup.xnview.com/viewtopic.php?t=43510
2381: [Bug] Message about converting in RGB model - http://newsgroup.xnview.com/viewtopic.php?t=38733
2380: [Bug] Bad preview when returning to browser - http://newsgroup.xnview.com/viewtopic.php?t=43486
2379: [Bug] IPTC: 'Replace only...' should not be used with 'write' - http://newsgroup.xnview.com/viewtopic.php?t=43497
2378: [Bug] Face tag detection - http://newsgroup.xnview.com/viewtopic.php?t=43426
2377: [Bug] Categories assignment problem - http://newsgroup.xnview.com/viewtopic.php?t=43422
2376: [Bug] Two pass rendering setting
2375: [Bug] XMP template can't be loaded - http://newsgroup.xnview.com/viewtopic.php?t=43183
2373: [Bug] Picture orientation & cache - http://newsgroup.xnview.com/viewtopic.php?t=43134
2372: [Bug] Open archive on unicode subfolder - http://newsgroup.xnview.com/viewtopic.php?t=43421
2371: [Bug] Folder view not updated after create folder/rename - http://newsgroup.xnview.com/viewtopic.php?t=43398
2370: [Bug] XMP on RAW files - http://newsgroup.xnview.com/viewtopic.php?t=43411
2369: [Bug] TIFF 16/32bits greyscale - http://newsgroup.xnview.com/viewtopic.php?t=43013
2368: [Bug] Crash when closing thumbnail creation + ICC
2367: [Bug] RAW Automatic brightness setting not used - http://newsgroup.xnview.com/viewtopic.php?t=42732
2366: [Bug] Edit text in category pane - http://newsgroup.xnview.com/viewtopic.php?t=43385
2365: [Bug] Close unsaved view - http://newsgroup.xnview.com/viewtopic.php?t=43372
2364: [Bug] Video thumbnail problem - http://newsgroup.xnview.com/viewtopic.php?t=43389
2363: [Bug] GMIC - http://newsgroup.xnview.com/viewtopic.php?t=43378
2362: [Bug] EXIF panel empty after tag face - http://newsgroup.xnview.com/viewtopic.php?t=43320
2361: [Bug] Folder thumbnails - ignore EXIF rotation information - http://newsgroup.xnview.com/viewtopic.php?t=43379
2360: [Bug] 'File>Save' greyed for capture - http://newsgroup.xnview.com/viewtopic.php?t=43334
2359: [Bug] XMP face detection - http://newsgroup.xnview.com/viewtopic.php?t=43362
2029: [Bug] Canvas resize - restore default - http://newsgroup.xnview.com/viewtopic.php?t=41707
2358: [Bug] EXIF Image unique ID - http://newsgroup.xnview.com/viewtopic.php?t=43345
2357: [Bug] .xmp shown, missing rule in Settings>Companion
2356: [Bug] Import&Sort: JPG not imported - http://newsgroup.xnview.com/viewtopic.php?t=43314
Changelog 1.0.0:
2345: [New] QOI format read support
2341: [New] LibjpegTurbo 2.1.3
2322: [New] HEIF 1.12.0
2321: [New] OpenJPEG 2.4.0
2178: [New] Archive (ZIP, RAR, CAB, 7-Zip, ...) support - http://newsgroup.xnview.com/viewtopic.php?t=29736
2335: [New] XMP fields in 'Labels' - http://newsgroup.xnview.com/viewtopic.php?t=43069
2334: [New] Sharpen setting in view mode - http://newsgroup.xnview.com/viewtopic.php?t=42090
2325: [New] Settings to customize little toolbar - http://newsgroup.xnview.com/viewtopic.php?t=41232
2324: [New] 'View as' mode as cmd - http://newsgroup.xnview.com/viewtopic.php?t=41232
2318: [New] Import: Companions correctly should be correctly imported - http://newsgroup.xnview.com/viewtopic.php?t=40793
2333: [New] "replace only if original value is empty" for Edit XMP - http://newsgroup.xnview.com/viewtopic.php?t=41657
2332: [New] Batch convert: film simulation - http://newsgroup.xnview.com/viewtopic.php?t=40318
2331: [New] Change timestamp: Independant date/time control - http://newsgroup.xnview.com/viewtopic.php?t=42239
1920: [New] Menu item to toggle high zoom quality - http://newsgroup.xnview.com/viewtopic.php?t=37347
2267: [New] Tag face: Add region - http://newsgroup.xnview.com/viewtopic.php?t=42899
2266: [New] Shift+Wheel to scroll - http://newsgroup.xnview.com/viewtopic.php?t=42887
2348: [New] Write settings dialog when saving - http://newsgroup.xnview.com/viewtopic.php?t=42971
2286: [New] Batch rename: History for 'from'/'with' replace field - http://newsgroup.xnview.com/viewtopic.php?t=39984
2327: [New] 'Show hidden files' as cmd_ - http://newsgroup.xnview.com/viewtopic.php?t=40848
2294: [New] Batch convert: Beep - http://newsgroup.xnview.com/viewtopic.php?t=39813
2308: [New] Fullscreen hide mouse setting - http://newsgroup.xnview.com/viewtopic.php?t=40946
2303: [New] Compare: Show CRC setting - http://newsgroup.xnview.com/viewtopic.php?t=43007
2353: [Bug] Duplicate categories - viewtopic.php?t=43208
2354: [Bug] Quick Search is case sensitive on categories - http://newsgroup.xnview.com/viewtopic.php?t=43202
2352: [Bug] DDS crash
2351: [Bug] Face tag & EXIF orientation - viewtopic.php?f=62&t=43209
2350: [Bug] Unicode & AVIF - viewtopic.php?f=62&t=43220
2349: [Bug] Folder's thumbnail, RAW orientation - viewtopic.php?f=62&t=43160
2347: [Bug] Resize dialog: DPI change - http://newsgroup.xnview.com/viewtopic.php?t=43133
2346: [Bug] Crop size in cm - http://newsgroup.xnview.com/viewtopic.php?t=43132
2344: [Bug] Preview panel tabified & update - http://newsgroup.xnview.com/viewtopic.php?t=43088
2343: [Bug] PNG tRNS & 24bits
2342: [Bug] HiDPI scaling & 100% - http://newsgroup.xnview.com/viewtopic.php?t=43108
2340: [Bug] MacOS: Unresponsive when browsing network share - http://newsgroup.xnview.com/viewtopic.php?t=42879
2339: [Bug] Batch rename: rating & color label - http://newsgroup.xnview.com/viewtopic.php?t=43107
2338: [Bug] MacOS: Tabbar grows instead of showing buttons - http://newsgroup.xnview.com/viewtopic.php?t=43095
2337: [Bug] 'Open container folder' when show in subfolder - http://newsgroup.xnview.com/viewtopic.php?t=43100
2336: [Bug] WebP for thumbnail cache & RGBA thumbnail - http://newsgroup.xnview.com/viewtopic.php?t=43098
2330: [Bug] 'Automatically apply parent keywords' - http://newsgroup.xnview.com/viewtopic.php?t=42945
2329: [Bug] Rename category & Shortcut - http://newsgroup.xnview.com/viewtopic.php?t=42946
2328: [Bug] Relative zoom value - http://newsgroup.xnview.com/viewtopic.php?t=42605
2326: [Bug] Next/previous file does not work for svg files - http://newsgroup.xnview.com/viewtopic.php?t=41100
2323: [Bug] WebP 1.2.2
2320: [Bug] Thumbnail processing stopped when last file is selected - http://newsgroup.xnview.com/viewtopic.php?t=43048
2319: [Bug] Slow info loading from catalog (edit mode or detail view mode)
2317: [Bug] RAW & thumbnail orientation - http://newsgroup.xnview.com/viewtopic.php?t=43066
2316: [Bug] Zoom selection problem on RAW - http://newsgroup.xnview.com/viewtopic.php?t=43025
2315: [Bug] Batch convert: ICC convert crash - http://newsgroup.xnview.com/viewtopic.php?t=43055
2314: [Bug] Delay when expanding folder tree - http://newsgroup.xnview.com/viewtopic.php?t=43057
2313: [Bug] New file is not crrectly selected - http://newsgroup.xnview.com/viewtopic.php?t=43059
2312: [Bug] Background color setting in Paint dialog - http://newsgroup.xnview.com/viewtopic.php?t=41268
2311: [Bug] HEIC save corrupted file - http://newsgroup.xnview.com/viewtopic.php?t=42986
2310: [Bug] HEIC saving problem - http://newsgroup.xnview.com/viewtopic.php?t=42986
2309: [Bug] Image moves when selecting to/from right and/or bottom window edges - http://newsgroup.xnview.com/viewtopic.php?t=40858
2307: [Bug] Fullscreen from browser {File Index} include folders - http://newsgroup.xnview.com/viewtopic.php?t=40880
2306: [Bug] "reset auto image size with next/previous file" - http://newsgroup.xnview.com/viewtopic.php?t=39432
2305: [Bug] Bookmarks must follow order of bookmark.ini - http://newsgroup.xnview.com/viewtopic.php?t=42987
2304: [Bug] Info shows 8bits for RGB 16bits file (targa)
2302: [Bug] EXIF ImgDirection as float - http://newsgroup.xnview.com/viewtopic.php?t=43008
2301: [Bug] JPEGXL greyscale output - http://newsgroup.xnview.com/viewtopic.php?t=42996
2300: [Bug] Problem to load TIFF 16bits float - http://newsgroup.xnview.com/viewtopic.php?t=42991
2299: [Bug] ICC can't be disable for WebP
2298: [Bug] Compare: Crash with recursive files - http://newsgroup.xnview.com/viewtopic.php?t=42979
2297: [Bug] Delete last item show item not filtered - http://newsgroup.xnview.com/viewtopic.php?t=40757
2296: [Bug] DNG greyscale crash
2295: [Bug] Issue when moving category - http://newsgroup.xnview.com/viewtopic.php?t=40516
2293: [Bug] Linux: Companion & batch rename - http://newsgroup.xnview.com/viewtopic.php?t=40179
2292: [Bug] Category Sets not correctly updated - http://newsgroup.xnview.com/viewtopic.php?t=39413
2291: [Bug] Quick filter & new files - http://newsgroup.xnview.com/viewtopic.php?t=38983
2290: [Bug] CLTR+Wheel open context menu - http://newsgroup.xnview.com/viewtopic.php?t=38870
2289: [Bug] JPEG as companion file - http://newsgroup.xnview.com/viewtopic.php?t=39902
2288: [Bug] Compare & results from filter panel - http://newsgroup.xnview.com/viewtopic.php?t=40198
2287: [Bug] Shift+Del doesn't delete companion files - http://newsgroup.xnview.com/viewtopic.php?t=40036
2285: [Bug] Bad thumbnail of changed file - http://newsgroup.xnview.com/viewtopic.php?t=38033
2284: [Bug] Multiselection wrong preview - http://newsgroup.xnview.com/viewtopic.php?t=41374
2283: [Bug] Resize not correct when using percent - http://newsgroup.xnview.com/viewtopic.php?t=42966
2282: [Bug] File type colors problem - http://newsgroup.xnview.com/viewtopic.php?t=42922
2281: [Bug] Edit IPTC: merge datas - http://newsgroup.xnview.com/viewtopic.php?t=42925
2280: [Bug] APNG - http://newsgroup.xnview.com/viewtopic.php?t=42932
2279: [Bug] 'Thumbnails view only' - http://newsgroup.xnview.com/viewtopic.php?t=42943
2278: [Bug] Batch rename: Duplicate suffix - http://newsgroup.xnview.com/viewtopic.php?t=42952
2277: [Bug] XMP fields not updated after 'Edit XMP' - http://newsgroup.xnview.com/viewtopic.php?t=42942
2276: [Bug] {DPI} bad value after 'Edit XMP' - http://newsgroup.xnview.com/viewtopic.php?t=42942
2275: [Bug] XCF compositing - http://newsgroup.xnview.com/viewtopic.php?t=42905
2273: [Bug] Sidecar not loaded for tooltips - http://newsgroup.xnview.com/viewtopic.php?t=42913
2272: [Bug] RAW saving
2271: [Bug] Edit IPTC: 'Clear fields' doesn't clear country code
2270: [Bug] Tooltips {Annotation} not updated after editing - http://newsgroup.xnview.com/viewtopic.php?t=42913
2269: [Bug] Portrait RAW files are shown in landscape orientation when categorized - http://newsgroup.xnview.com/viewtopic.php?t=42868
2268: [Bug] DPX grey - http://newsgroup.xnview.com/viewtopic.php?t=42910
2265: [Bug] Edit IPTC/XMP: / instead of \ - http://newsgroup.xnview.com/viewtopic.php?t=42898
2264: [Bug] Tag face UI
2263: [Bug] Wrong index/count in titlebar - http://newsgroup.xnview.com/viewtopic.php?t=42893
2262: [Bug] DNG resolution - http://newsgroup.xnview.com/viewtopic.php?t=42892
2203: [Bug] Mac: 'open in finder' dont select/focus file - http://newsgroup.xnview.com/viewtopic.php?t=42632
XnView MP 1.3.1
XnView MP 1.3.1
Re: XnView MP 1.3.1
with auto play video ..unticked... going to a video next//prev...the player timeline bar starts playing.. as if it it were playing the video..
with auto play video ticked.. works as expected...
- Moderator & Librarian
Re: XnView MP 1.3.1
Re: XnView MP 1.3.1
Time: 2022.11.02 - 11:50 AM
As far as I am concerned all DL-Links of "Windows 7/8/10/11 Setup Win 32bit" still refer to the former version 1.3.0 - the portable version is fine and already 1.3.1.
here:
https://www.xnview.com/de/xnviewmp/#downloads
=> 1.3.0
and here:
viewtopic.php?t=44045
=> 1.3.0
Thank you very much for changing this!
Cheers!
here:
=> 1.3.0
and here:
=> 1.3.0
Cheers!
Re: XnView MP 1.3.1
Hi!
XN-VIEW MP (1.31) tries to open & pulls up the browser screen, but the thumbnails aren't showing, just the icons.
I then get a “not responding” message, & the program freezes & I have to open Task Manager to make it go away.
Please advie.
Thanks,
Bob
Please advie.
Thanks,
Bob
