B2: Network bug - crash
Dreamer
Post by Dreamer »
When I try to enter to the folder on network (through context menu or browser), but I don't have rights, error dialog (below) appears.
I mean - I have access/rights for some folders, but if new folders are created, I can't enter there. In other programs, e.g. file manager I have just dialog "Access is denied" - no crash.
"XnView for Windows 9x/NT/2000/Me/Xp has encountered a problem and needs to close. We are sorry for the inconvenience."
XnView 1.82 Beta2
Dreamer
Post by Dreamer »
Not fixed in beta 3. I sill have a crash (after 2 error dialogs).
Dreamer wrote:Not fixed in beta 3. I sill have a crash (after 2 error dialogs).
Strange, i have only 1 dialog, and no crash
Dreamer
Post by Dreamer »
Hmmm... I use network drive / another letter and path is hidden, like \\CompName\Data$. Symbol '$' is used to hide it for other users. Maybe this is the problem?
Xyzzy
Post by Xyzzy »
Dreamer, what is the structure of folders/permissions that cause problems? What steps to reproduce?
X.
Dreamer
Post by Dreamer »
Xyzzy wrote:Dreamer, what is the structure of folders/permissions that cause problems? What steps to reproduce?
X.
- create and share 1 folder and one image on computer 2
- share this folder as \\CompName\FolderName$ ($ is important)
- mount this folder as drive X: on computer 1 (F11 in file managers)
- open image
= it should be OK
- create subfolder and place another image there on comp. 2
- try to enter this subfolder in xnview ('4in1' thumb. view)
- important! you must double-click the folder in the file list, not folder tree!
= 2 dialogs+crash
- tested also in details and icon view
= result, 1 dialog and crash
X.
- open image
= it should be OK
= 2 dialogs+crash
I can't reproduce it with your steps :-(
Strange, the FolderName$ is not shown in network of windows explorer
Xyzzy
Post by Xyzzy »
$ at the end of share name makes it invisible.
X.
Xyzzy wrote:$ at the end of share name makes it invisible.
Ok, thanks :-)
Xyzzy
Post by Xyzzy »
I reproduced it at last in in rc1.
The sub-folder I made first with Full-control permissions, so that thumbnails for it and image inside were created. Then I removed all permissions from the subfolder. XnView (now in main shared folder) displayed error when trying to access the subfolder (OK), but folder 4in1 icon appeared and disappeared when refreshing folder with F5 and/or Ctrl+R (strange). In the end I got message mentioned by Dreamer in the first post- crash.
X.
Dreamer
Post by Dreamer »
No crash in RC2, but also no error dialog and focus is switched to the first item. :?
Dreamer
Post by Dreamer »
Dreamer wrote:No crash in RC2, but also no error dialog and focus is switched to the first item. :?
No change in RC3.
