Select by extension
stevehero
Select by extension
Post by stevehero »
Being able to select by extension would be a nice feature.
Re: Select by extension
Post by michel038 »
Is this method a way to achieve what you want ?
View > Sort by > show headers
Click on "Type" header ... so files ar sorted by type
Other settings :
View > View as > Details
Now you can move or add or remove columns, and if necessary enable "Extension" column, and bring it to the left ...
and go back to : View > View as > Thumbnails + labels
In addition to Michel's good suggestions above: You can use the quick filter in the toolbar. In the quick filter you enter the desired extension (e.g. ".png") this will display all files that match this pattern, only. Then press Ctrl + A for selecting all files.
helmut wrote: Mon Sep 26, 2022 8:55 pm In addition to Michel's good suggestions above: You can use the quick filter in the toolbar. In the quick filter you enter the desired extension (e.g. ".png") this will display all files that match this pattern, only. Then press Ctrl + A for selecting all files.
I don't see that option on the toolbar of my installation of XnView MP 1.3 with default toolbar settings, but maybe I'm missing it as I rarely use the browser functions.
Either way, the following menu option looks like a useful alternative solution: View > Sort by > Extension.
