Integration to folder context menu - also add to background context menu
KillyMXI
Post by KillyMXI »
What I expect to be able to do:
Right click in the empty space of any folder and open XnViewMP from there.
What currently works:
Integration is turned on in the settings.
I have to get out of the folder and right click on its icon to get the context menu entry of XnViewMP.
The solution:
Explorer integration should add one more entry to the registry.
Currently XnViewMP adds to
HKEY_CLASSES_ROOT\Directory\shell
It should also add to
HKEY_CLASSES_ROOT\Directory\Background\shell
Thanks
ckit
Re: Integration to folder context menu - also add to background context menu
Post by ckit »
Why not just use
HKEY_CLASSES_ROOT\*\shell\XnViewMP
AMD Ryzen 3 3300X 3.8Ghz, 16Gb DDR4, RX6600XT with Dell U2520D at 2560x1440@60Hz
Windows 11 Pro x64 22H2, PowerToys and Wintoys
