Undo function for deleted files
Pcdoedel
Post by Pcdoedel »
I would be great to have a undo-function for deleted files as it is done in the explorer and as well in the old classic version. The only workaround at the moment is to switch to the explorer and the folder and use CTRL+Z. It would be much better if this function would exist directly within XnView.
