XnView MP 1.2.0
XnView MP 1.2.0
Please, don't post bugs or requests in this topic!
You can download XnView MP 1.02 here:
Windows x32 ZIP version SHA256: D917390E8C515FD124542A31D0E90B2A7C7CC6A47439980E4ECCDD26CC47CA2A
Windows x32 SETUP version SHA256: ADAF96959C736DFB1C1E23EBEFF8496E850AC1E29AE169E32EE83F7A47229E61
Windows x64 ZIP version SHA256: 602292DFAAA2E8D530430FC203F6D7D4DA2AFF634D5E9C787F11C8ABADBAFC8B
Windows x64 SETUP version SHA256: 151C10FBF386996C60378C69F77BDAC55759F6DE1F5353B8D1529F017DFA93BC
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: 55D6232013A29A9F2818809F0BCB032AD93676A2783BC7445565DCB5CF6D7F7B
Linux x64 TGZ version SHA256: 4DE4F212B28D273C438CD41901C597F4F8F52DC24DD00C6F410A7AF2A8A4346C
Linux x64 DEB version SHA256: EBBD2BF889615CBA454C6F32CA6B92D4FD1231D54008971CA0DDA3A0F5B16D00
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.02:
2415: [New] Libarchive 3.6.1
2411: [New] Convert: files in NConvert exported bat - http://newsgroup.xnview.com/viewtopic.php?t=43599
2406: [New] XMP Acdsee face region fields
2417: [Bug] AV1 video file thumbnailing
2416: [Bug] Icons in archive file - http://newsgroup.xnview.com/viewtopic.php?t=43725
2414: [Bug] Grey tiff 16 bits - http://newsgroup.xnview.com/viewtopic.php?t=43733
2396: [Bug] When saving, cancel in Write settings must not save - http://newsgroup.xnview.com/viewtopic.php?t=43555
2413: [Bug] Slideshow: Filename in sld with = char - http://newsgroup.xnview.com/viewtopic.php?t=43706
2412: [Bug] Grid not correctly restored - http://newsgroup.xnview.com/viewtopic.php?t=43715
2410: [Bug] Search: Category parent always selected & 'apply parent...' - http://newsgroup.xnview.com/viewtopic.php?t=43682
2409: [Bug] Suggested categories & 'apply to parent' - http://newsgroup.xnview.com/viewtopic.php?t=43698
2408: [Bug] Screen capture filename - http://newsgroup.xnview.com/viewtopic.php?t=43456
2407: [Bug] Statusbar 'file date' does not match settings - http://newsgroup.xnview.com/viewtopic.php?t=43701
Changelog 1.01:
2405: [New] MDK SDK instead of QtAV for video support
2374: [New] Edit IPTC/XMP: library
2392: [New] 'Save frame as' http://newsgroup.xnview.com/viewtopic.php?t=43526
2389: [New] Capture: Output folder - http://newsgroup.xnview.com/viewtopic.php?t=43456
2404: [Bug] GEM IMG crash - CVE Thanks to Danis Jiang
2403: [Bug] Abort in Search dialog - http://newsgroup.xnview.com/viewtopic.php?t=43657
2402: [Bug] If an error occurs when saving, no message
2401: [Bug] Bad mouse cursor in crop - http://newsgroup.xnview.com/viewtopic.php?t=43516
2400: [Bug] 'Show grid' not always restored - http://newsgroup.xnview.com/viewtopic.php?t=43610
2399: [Bug] Lock zoom not kept - http://newsgroup.xnview.com/viewtopic.php?t=43602
2398: [Bug] Contact sheet: size not restored correctly - http://newsgroup.xnview.com/viewtopic.php?t=43619
2397: [Bug] Acquire into: ISO date - http://newsgroup.xnview.com/viewtopic.php?t=43533
2395: [Bug] Edit comment: 'Write all' must close dialog - http://newsgroup.xnview.com/viewtopic.php?t=43615
2394: [Bug] Mac: Slideshow - when choosing color, dialog go to background - http://newsgroup.xnview.com/viewtopic.php?t=43575
2393: [Bug] White balance preset - http://newsgroup.xnview.com/viewtopic.php?t=43536
2391: [Bug] Wrong video orientation - http://newsgroup.xnview.com/viewtopic.php?t=39439
2390: [Bug] 'Update files from catalog' doesn't use settings - http://newsgroup.xnview.com/viewtopic.php?t=43489
2388: [Bug] Settings>Info - 'always in fullscreen' unchecked - http://newsgroup.xnview.com/viewtopic.php?t=43509
2387: [Bug] TTF thumbnail crash - http://newsgroup.xnview.com/viewtopic.php?t=39404
2386: [Bug] Export & Icc profile - http://newsgroup.xnview.com/viewtopic.php?t=43506
2385: [Bug] 'Convert to 256' shuffles colormap - http://newsgroup.xnview.com/viewtopic.php?t=43513
2384: [Bug] JPEGXL lossless output file size - http://newsgroup.xnview.com/viewtopic.php?t=43479
2383: [Bug] Batch convert: Film simulation parameters - http://newsgroup.xnview.com/viewtopic.php?t=43508
2382: [Bug] Edit mode: Bad file information in titlebar - http://newsgroup.xnview.com/viewtopic.php?t=43510
2381: [Bug] Message about converting in RGB model - http://newsgroup.xnview.com/viewtopic.php?t=38733
2380: [Bug] Bad preview when returning to browser - http://newsgroup.xnview.com/viewtopic.php?t=43486
2379: [Bug] IPTC: 'Replace only...' should not be used with 'write' - http://newsgroup.xnview.com/viewtopic.php?t=43497
2378: [Bug] Face tag detection - http://newsgroup.xnview.com/viewtopic.php?t=43426
2377: [Bug] Categories assignment problem - http://newsgroup.xnview.com/viewtopic.php?t=43422
2376: [Bug] Two pass rendering setting
2375: [Bug] XMP template can't be loaded - http://newsgroup.xnview.com/viewtopic.php?t=43183
2373: [Bug] Picture orientation & cache - http://newsgroup.xnview.com/viewtopic.php?t=43134
2372: [Bug] Open archive on unicode subfolder - http://newsgroup.xnview.com/viewtopic.php?t=43421
2371: [Bug] Folder view not updated after create folder/rename - http://newsgroup.xnview.com/viewtopic.php?t=43398
2370: [Bug] XMP on RAW files - http://newsgroup.xnview.com/viewtopic.php?t=43411
2369: [Bug] TIFF 16/32bits greyscale - http://newsgroup.xnview.com/viewtopic.php?t=43013
2368: [Bug] Crash when closing thumbnail creation + ICC
2367: [Bug] RAW Automatic brightness setting not used - http://newsgroup.xnview.com/viewtopic.php?t=42732
2366: [Bug] Edit text in category pane - http://newsgroup.xnview.com/viewtopic.php?t=43385
2365: [Bug] Close unsaved view - http://newsgroup.xnview.com/viewtopic.php?t=43372
2364: [Bug] Video thumbnail problem - http://newsgroup.xnview.com/viewtopic.php?t=43389
2363: [Bug] GMIC - http://newsgroup.xnview.com/viewtopic.php?t=43378
2362: [Bug] EXIF panel empty after tag face - http://newsgroup.xnview.com/viewtopic.php?t=43320
2361: [Bug] Folder thumbnails - ignore EXIF rotation information - http://newsgroup.xnview.com/viewtopic.php?t=43379
2360: [Bug] 'File>Save' greyed for capture - http://newsgroup.xnview.com/viewtopic.php?t=43334
2359: [Bug] XMP face detection - http://newsgroup.xnview.com/viewtopic.php?t=43362
2029: [Bug] Canvas resize - restore default - http://newsgroup.xnview.com/viewtopic.php?t=41707
2358: [Bug] EXIF Image unique ID - http://newsgroup.xnview.com/viewtopic.php?t=43345
2357: [Bug] .xmp shown, missing rule in Settings>Companion
2356: [Bug] Import&Sort: JPG not imported - http://newsgroup.xnview.com/viewtopic.php?t=43314
Changelog 1.00:
2345: [New] QOI format read support
2341: [New] LibjpegTurbo 2.1.3
2322: [New] HEIF 1.12.0
2321: [New] OpenJPEG 2.4.0
2178: [New] Archive (ZIP, RAR, CAB, 7-Zip, ...) support - http://newsgroup.xnview.com/viewtopic.php?t=29736
2335: [New] XMP fields in 'Labels' - http://newsgroup.xnview.com/viewtopic.php?t=43069
2334: [New] Sharpen setting in view mode - http://newsgroup.xnview.com/viewtopic.php?t=42090
2325: [New] Settings to customize little toolbar - http://newsgroup.xnview.com/viewtopic.php?t=41232
2324: [New] 'View as' mode as cmd - http://newsgroup.xnview.com/viewtopic.php?t=41232
2318: [New] Import: Companions correctly should be correctly imported - http://newsgroup.xnview.com/viewtopic.php?t=40793
2333: [New] "replace only if original value is empty" for Edit XMP - http://newsgroup.xnview.com/viewtopic.php?t=41657
2332: [New] Batch convert: film simulation - http://newsgroup.xnview.com/viewtopic.php?t=40318
2331: [New] Change timestamp: Independant date/time control - http://newsgroup.xnview.com/viewtopic.php?t=42239
1920: [New] Menu item to toggle high zoom quality - http://newsgroup.xnview.com/viewtopic.php?t=37347
2267: [New] Tag face: Add region - http://newsgroup.xnview.com/viewtopic.php?t=42899
2266: [New] Shift+Wheel to scroll - http://newsgroup.xnview.com/viewtopic.php?t=42887
2348: [New] Write settings dialog when saving - http://newsgroup.xnview.com/viewtopic.php?t=42971
2286: [New] Batch rename: History for 'from'/'with' replace field - http://newsgroup.xnview.com/viewtopic.php?t=39984
2327: [New] 'Show hidden files' as cmd_ - http://newsgroup.xnview.com/viewtopic.php?t=40848
2294: [New] Batch convert: Beep - http://newsgroup.xnview.com/viewtopic.php?t=39813
2308: [New] Fullscreen hide mouse setting - http://newsgroup.xnview.com/viewtopic.php?t=40946
2303: [New] Compare: Show CRC setting - http://newsgroup.xnview.com/viewtopic.php?t=43007
2353: [Bug] Duplicate categories - viewtopic.php?t=43208
2354: [Bug] Quick Search is case sensitive on categories - http://newsgroup.xnview.com/viewtopic.php?t=43202
2352: [Bug] DDS crash
2351: [Bug] Face tag & EXIF orientation - viewtopic.php?f=62&t=43209
2350: [Bug] Unicode & AVIF - viewtopic.php?f=62&t=43220
2349: [Bug] Folder's thumbnail, RAW orientation - viewtopic.php?f=62&t=43160
2347: [Bug] Resize dialog: DPI change - http://newsgroup.xnview.com/viewtopic.php?t=43133
2346: [Bug] Crop size in cm - http://newsgroup.xnview.com/viewtopic.php?t=43132
2344: [Bug] Preview panel tabified & update - http://newsgroup.xnview.com/viewtopic.php?t=43088
2343: [Bug] PNG tRNS & 24bits
2342: [Bug] HiDPI scaling & 100% - http://newsgroup.xnview.com/viewtopic.php?t=43108
2340: [Bug] MacOS: Unresponsive when browsing network share - http://newsgroup.xnview.com/viewtopic.php?t=42879
2339: [Bug] Batch rename: rating & color label - http://newsgroup.xnview.com/viewtopic.php?t=43107
2338: [Bug] MacOS: Tabbar grows instead of showing buttons - http://newsgroup.xnview.com/viewtopic.php?t=43095
2337: [Bug] 'Open container folder' when show in subfolder - http://newsgroup.xnview.com/viewtopic.php?t=43100
2336: [Bug] WebP for thumbnail cache & RGBA thumbnail - http://newsgroup.xnview.com/viewtopic.php?t=43098
2330: [Bug] 'Automatically apply parent keywords' - http://newsgroup.xnview.com/viewtopic.php?t=42945
2329: [Bug] Rename category & Shortcut - http://newsgroup.xnview.com/viewtopic.php?t=42946
2328: [Bug] Relative zoom value - http://newsgroup.xnview.com/viewtopic.php?t=42605
2326: [Bug] Next/previous file does not work for svg files - http://newsgroup.xnview.com/viewtopic.php?t=41100
2323: [Bug] WebP 1.2.2
2320: [Bug] Thumbnail processing stopped when last file is selected - http://newsgroup.xnview.com/viewtopic.php?t=43048
2319: [Bug] Slow info loading from catalog (edit mode or detail view mode)
2317: [Bug] RAW & thumbnail orientation - http://newsgroup.xnview.com/viewtopic.php?t=43066
2316: [Bug] Zoom selection problem on RAW - http://newsgroup.xnview.com/viewtopic.php?t=43025
2315: [Bug] Batch convert: ICC convert crash - http://newsgroup.xnview.com/viewtopic.php?t=43055
2314: [Bug] Delay when expanding folder tree - http://newsgroup.xnview.com/viewtopic.php?t=43057
2313: [Bug] New file is not crrectly selected - http://newsgroup.xnview.com/viewtopic.php?t=43059
2312: [Bug] Background color setting in Paint dialog - http://newsgroup.xnview.com/viewtopic.php?t=41268
2311: [Bug] HEIC save corrupted file - http://newsgroup.xnview.com/viewtopic.php?t=42986
2310: [Bug] HEIC saving problem - http://newsgroup.xnview.com/viewtopic.php?t=42986
2309: [Bug] Image moves when selecting to/from right and/or bottom window edges - http://newsgroup.xnview.com/viewtopic.php?t=40858
2307: [Bug] Fullscreen from browser {File Index} include folders - http://newsgroup.xnview.com/viewtopic.php?t=40880
2306: [Bug] "reset auto image size with next/previous file" - http://newsgroup.xnview.com/viewtopic.php?t=39432
2305: [Bug] Bookmarks must follow order of bookmark.ini - http://newsgroup.xnview.com/viewtopic.php?t=42987
2304: [Bug] Info shows 8bits for RGB 16bits file (targa)
2302: [Bug] EXIF ImgDirection as float - http://newsgroup.xnview.com/viewtopic.php?t=43008
2301: [Bug] JPEGXL greyscale output - http://newsgroup.xnview.com/viewtopic.php?t=42996
2300: [Bug] Problem to load TIFF 16bits float - http://newsgroup.xnview.com/viewtopic.php?t=42991
2299: [Bug] ICC can't be disable for WebP
2298: [Bug] Compare: Crash with recursive files - http://newsgroup.xnview.com/viewtopic.php?t=42979
2297: [Bug] Delete last item show item not filtered - http://newsgroup.xnview.com/viewtopic.php?t=40757
2296: [Bug] DNG greyscale crash
2295: [Bug] Issue when moving category - http://newsgroup.xnview.com/viewtopic.php?t=40516
2293: [Bug] Linux: Companion & batch rename - http://newsgroup.xnview.com/viewtopic.php?t=40179
2292: [Bug] Category Sets not correctly updated - http://newsgroup.xnview.com/viewtopic.php?t=39413
2291: [Bug] Quick filter & new files - http://newsgroup.xnview.com/viewtopic.php?t=38983
2290: [Bug] CLTR+Wheel open context menu - http://newsgroup.xnview.com/viewtopic.php?t=38870
2289: [Bug] JPEG as companion file - http://newsgroup.xnview.com/viewtopic.php?t=39902
2288: [Bug] Compare & results from filter panel - http://newsgroup.xnview.com/viewtopic.php?t=40198
2287: [Bug] Shift+Del doesn't delete companion files - http://newsgroup.xnview.com/viewtopic.php?t=40036
2285: [Bug] Bad thumbnail of changed file - http://newsgroup.xnview.com/viewtopic.php?t=38033
2284: [Bug] Multiselection wrong preview - http://newsgroup.xnview.com/viewtopic.php?t=41374
2283: [Bug] Resize not correct when using percent - http://newsgroup.xnview.com/viewtopic.php?t=42966
2282: [Bug] File type colors problem - http://newsgroup.xnview.com/viewtopic.php?t=42922
2281: [Bug] Edit IPTC: merge datas - http://newsgroup.xnview.com/viewtopic.php?t=42925
2280: [Bug] APNG - http://newsgroup.xnview.com/viewtopic.php?t=42932
2279: [Bug] 'Thumbnails view only' - http://newsgroup.xnview.com/viewtopic.php?t=42943
2278: [Bug] Batch rename: Duplicate suffix - http://newsgroup.xnview.com/viewtopic.php?t=42952
2277: [Bug] XMP fields not updated after 'Edit XMP' - http://newsgroup.xnview.com/viewtopic.php?t=42942
2276: [Bug] {DPI} bad value after 'Edit XMP' - http://newsgroup.xnview.com/viewtopic.php?t=42942
2275: [Bug] XCF compositing - http://newsgroup.xnview.com/viewtopic.php?t=42905
2273: [Bug] Sidecar not loaded for tooltips - http://newsgroup.xnview.com/viewtopic.php?t=42913
2272: [Bug] RAW saving
2271: [Bug] Edit IPTC: 'Clear fields' doesn't clear country code
2270: [Bug] Tooltips {Annotation} not updated after editing - http://newsgroup.xnview.com/viewtopic.php?t=42913
2269: [Bug] Portrait RAW files are shown in landscape orientation when categorized - http://newsgroup.xnview.com/viewtopic.php?t=42868
2268: [Bug] DPX grey - http://newsgroup.xnview.com/viewtopic.php?t=42910
2265: [Bug] Edit IPTC/XMP: / instead of \ - http://newsgroup.xnview.com/viewtopic.php?t=42898
2264: [Bug] Tag face UI
2263: [Bug] Wrong index/count in titlebar - http://newsgroup.xnview.com/viewtopic.php?t=42893
2262: [Bug] DNG resolution - http://newsgroup.xnview.com/viewtopic.php?t=42892
2203: [Bug] Mac: 'open in finder' dont select/focus file - http://newsgroup.xnview.com/viewtopic.php?t=42632
Changelog 0.99.7:
2256: [New] Resize: Lanczos2 filter - http://newsgroup.xnview.com/viewtopic.php?t=42816
2255: [New] 'Use checkerboard pattern' in menu - http://newsgroup.xnview.com/viewtopic.php?t=42847
2234: [New] XMP in tooltips - http://newsgroup.xnview.com/viewtopic.php?t=42714
2227: [New] Category menu: Parent label on top of submenu - http://newsgroup.xnview.com/viewtopic.php?t=42575
2226: [New] Album: Import/Export Bridge collection
2246: [New] Batch convert: Antialiasing option for 'Text'
2261: [Bug] Bottom line not visible on HDPI - http://newsgroup.xnview.com/viewtopic.php?t=42783
2260: [Bug] Image is not antialiased when zoom % matches HiDPI scaling - http://newsgroup.xnview.com/viewtopic.php?t=42784
2259: [Bug] Linux: SaveAs always use original date file
2258: [Bug] Join: Need to use sRGB color profile - http://newsgroup.xnview.com/viewtopic.php?t=42853
2257: [Bug] Remove/Extract alpha channel on 8bits image - http://newsgroup.xnview.com/viewtopic.php?t=42824
2254: [Bug] MacOS: EXIF on HEIC file - http://newsgroup.xnview.com/viewtopic.php?t=42838
2253: [Bug] PDF crash
2252: [Bug] Slideshow: Close when using timer at the end - http://newsgroup.xnview.com/viewtopic.php?t=42820
2251: [Bug] Slideshow & high DPI scaling - http://newsgroup.xnview.com/viewtopic.php?t=42811
2250: [Bug] Tag Face: People list not updated - http://newsgroup.xnview.com/viewtopic.php?t=42793
2249: [Bug] Fullscreen info truncated (HTML) - http://newsgroup.xnview.com/viewtopic.php?t=42708
2248: [Bug] Rating in Edit mode doen't update browser - http://newsgroup.xnview.com/viewtopic.php?t=42807
2247: [Bug] Text in statusbar clipped
2245: [Bug] Pan on HiDPI with 1 image pixel = 1 screen pixel
2244: [Bug] Batch rename: option to remove diacritic character - http://newsgroup.xnview.com/viewtopic.php?t=42617
2243: [Bug] Tag Face: XMP metadata not always written - http://newsgroup.xnview.com/viewtopic.php?t=42
2242: [Bug] Tag Face: Crash with grey images - http://newsgroup.xnview.com/viewtopic.php?t=42793
2241: [Bug] Windows: High DPI scaling problem - http://newsgroup.xnview.com/viewtopic.php?t=42756
2240: [Bug] Slideshow a animated file - http://newsgroup.xnview.com/viewtopic.php?t=42792
2239: [Bug] StatusBar: Bad image size in edit mode
2238: [Bug] Resize: Mode not applied - http://newsgroup.xnview.com/viewtopic.php?t=42767
2237: [Bug] Temporary file & reuse - http://newsgroup.xnview.com/viewtopic.php?t=42741
2236: [Bug] Print Selection: aspect ratio of preview image is distorted - http://newsgroup.xnview.com/viewtopic.php?t=42771
2235: [Bug] 'Print selection' not enabled in toolbar - http://newsgroup.xnview.com/viewtopic.php?t=42775
2233: [Bug] Zoom selection & high dpi scale - http://newsgroup.xnview.com/viewtopic.php?t=42718
2232: [Bug] StatusBar not correctly updated if Preview is hidden - http://newsgroup.xnview.com/viewtopic.php?t=42764
2231: [Bug] {File Index} in statusbar - http://newsgroup.xnview.com/viewtopic.php?t=42749
2230: [Bug] Remember last selected filename - http://newsgroup.xnview.com/viewtopic.php?t=42355
2229: [Bug] Open container on category list
2228: [Bug] Edit category's parent doesn't refresh tree - http://newsgroup.xnview.com/viewtopic.php?t=40521
2225: [Bug] Album: Create first show 2 entries
2219: [Bug] {Categories} and 'base path' - http://newsgroup.xnview.com/viewtopic.php?t=41992
2224: [Bug] JXR 128 RGBA - http://newsgroup.xnview.com/viewtopic.php?t=42750
2223: [Bug] Multipage create: Bad orientation for files with EXIF orientation
exener
Re: XnView MP 1.02
Post by exener »
Thank you for the update.
Please note that, according to my SHA256 hash tool, the SHA256 hash for the Win64 ZIP of version 1.02 currently available on https://www.xnview.com/en/xnviewmp/#downloads does not match:
Instead, it is:
09FE71323641C3864238EB64407736E440B3B06EDC39AAA7675AA1FFFF2919B4
I'm not sure if there is a problem, or the wrong SHA256 hash was accidentally posted above. Please let us know.
Also, please kindly note that the changelog posted on https://www.xnview.com/en/xnviewmp/#changelog is not current. It was last updated for version 1.00.
metal450
Re: XnView MP 1.2.0
Post by metal450 »
* Title of the thread says 1.2.0
* But the thread content itself says 1.0.2
* About dialog in the binary also says 1.0.2
* But the next version's changelog says 1.2.0: viewtopic.php?f=82&t=43826
* The main download page says 1.2.0
Seems like we should get our version numbers straight....
Moderator
Re: XnView MP 1.2.0
metal450 wrote: Sun Sep 11, 2022 4:13 amSeems like we should get our version numbers straight....
Right, there's room for interpretation which is no good. Correct is 1.2.0.
