1.01: Incorrectly displays 16 bit b/w TIFF
Aolei
Post by Aolei »
XnView: MP 1.01 64bits (Aug 8 2022)
OS: Windows 7 Pro 64bit
Cannot properly render 16 bit TIFF files
Effect: Image displays like a negative with incorrect pallette
1. Double-click a 16 bit b/w TIFF file (from Epson Scan 2)
Expected behaviour: In previous version 1.00.0 it displayed correctly (though I suspect reduced to 8 bit without notification to user).
In XnView Classic a warning is popped up "This picture will be converted to RGB with 8 bits per component" and then displays correctly.
Re: 1.01: Incorrectly displays 16 bit b/w TIFF
please send me a sample file
Aolei
Post by Aolei »
I think I replied by private message - but don't 100% understand the system as it says it is "Sent" but still seems to be in the Outbox. Please let me know if you didn't get it.
Aolei wrote: Sun Aug 21, 2022 11:50 pm I think I replied by private message - but don't 100% understand the system as it says it is "Sent" but still seems to be in the Outbox. Please let me know if you didn't get it.
PMs for some reason remain in the Outbox until the recipient reads them, so presumably Pierre hasn't read it yet.
As PMs do not support attachments, presumably you included a download link for the file you sent?
Aolei
Post by Aolei »
Yes - I included a link. When I first started this thread I tried to attach an image but there was a message indicating some quote or other site problem prevented me from doing so.
This problem is supposed to be fixed in XnView MP 1.02. Please check and confirm the bug fix here.
Aolei
Post by Aolei »
Thanks Pierre - I confirm the bug is fixed.
