question on 'embedded metadata for format that support (JPEG, TIFF, PNG), and sidecar for others'
kbyork
Post by kbyork »
In regards to:
viewtopic.php?f=95&t=38199
Re: Metadata in sidecar only for selected filetypes?
Post by xnview » Fri Nov 30, 2018 8:53 am
so you would like to use embedded metadata for format that support (JPEG, TIFF, PNG), and sidecar for others?
and
https://forum.xnview.com/viewtopic.php? ... 02#p178602
Re: How to save XMP sidecar files *only* for RAW images
post by Quagmire » Sun Jun 19, 2022 11:28 am
I just upgraded to v1.00 and this seems to be working now! Thanks, this program is amazing and has come a long way; I think I may finally be able to kick Adobe to the curb for cataloging and keywording.
  1. Does that mean this feature has been implemented?
  2. And (if so) how do I turn it ON & OFF?
Re: question on 'embedded metadata for format that support (JPEG, TIFF, PNG), and sidecar for others'
kbyork wrote: Thu Aug 11, 2022 10:29 pm
will be in 1.02
