Custom thumbnails for videos not displaying
kbyork
Post by kbyork »
Regarding an old post:
Custom thumbnails for videos not displaying viewtopic.php?f=82&t=42975
Post by MontanaFur » Wed Jan 26, 2022 8:20 pm
I also had found this problem! ...and since it still exists in the current version, I am chiming in on this bug report; in hopes that it gets attention.
I could send you an example video if you like;... or you could just make your own:
fmpeg.exe -hide_banner -i INPUTvid.mp4 -i thumbnail.jpg -map 0 -map 1 -c copy -disposition:v:1 attached_pic OUTPUTvid.mp4
Any video with an embedded thumbnail seems to fail to show the embedded version.
As stated in the original post; Windows Explorer correctly displays the embedded thumbs.
P.S.: when using the INFO pane > Properties tab: I see sections for: FILE, IMAGE, VIDEO, AUDIO
I had always thought that the IMAGE section was the embedded thumbnail.
Since it is not; what is it for? (if anything)
thanks,
Kevin
Re: Custom thumbnails for videos not displaying
yes please send me a sample file?
kbyork
Post by kbyork »
I forgot about needing to send you the video. My apologies...
Despite quite a bit of looking; I was not able to find the video that I was originally going to send you.
So I made a tiny one using ffmpeg.exe
hmm... how do I send it? A 7MB attachment causes a 'file too large' error.
kbyork
Post by kbyork »
Videos thumbnails can come from the embedded image or are auto-generated from the video itself.
I am guessing that XnView-MP is correctly detecting the embedded thumbnail image; but is preferring the auto-generated one.
Because (looking at INFO pane > PROPERTIES) you are detecting the thumbnail with correct resolution,etc.
POST SCRIPT: (looking at INFO pane > PROPERTIES) if the view does NOT have a thumbnail:
  • the properties of 'FILE', VIDEO' and 'AUDIO' are correctly updated.
  • But not the 'IMAGE' property. It keeps whatever was there the previous file that was examined.
kbyork
Post by kbyork »
(bump)
