0.99.7: Fixed ratio in crop, change number will transpose.
Mapaler
Post by Mapaler »
0.99.7
win10 64bit
I reply here but you may not notice. viewtopic.php?p=176430#p176430
Crop with a fixed scale, height greater than width. Click the number to modify the size.
The direction will change to, wider than high.
Re: 0.99.7: Fixed ratio in crop, change number will transpose.
