Convert to PJP
mickeybee
Convert to PJP
Post by mickeybee »
Hi. Im workin with a imageuploader and got stuck on .pjp files. Im looking for a image converter or app that saves in the .pjp format. I dont just wanna rename other progressive jpegs and hope for the best. Can XnViev convert to pjp ?
Re: Convert to PJP
it's not a jpeg file?
mickeybee
Re: Convert to PJP
Post by mickeybee »
Yes i guess its a .pjpg shortened to pjp . I read here XnView was the app to make them. http://en.filedict.com/pjp-progressive- ... age-56250/
Right now i just need a pjp file for testing.
Re: Convert to PJP
convert to jpeg, and change the extension
mickeybee
Re: Convert to PJP
Post by mickeybee »
Yes i can do that. But for testing purposes i would like to use a original plp file. Is there really no extra information in a pjp file? Why in that case do that format exist? Actually i dont need to now, i just need a pjp file and see if the image-uploader accept it. Renaming is a workaround and i cant be 100% sure it works when i report my findings
Re: Convert to PJP
sorry but i don't know
