Option to launch program using 'xnconvert -ini file.ini' not documented?
Is the command line option to launch XnConvert using xnconvert -ini file.ini documented anywhere?
Re: Option to launch program using 'xnconvert -ini file.ini' not documented?
no :) but it's the same as XnView MP
