Option to place .ini file in program folder
Please consider adding a setting option to place the .ini file in the program folder, in order to make the ZIP version portable, and to simplify running multiple instances of the program when required.
Re: Option to place .ini file in program folder
you can put .ini in program folder like XnView MP
xnview wrote: Thu Feb 24, 2022 3:09 pm you can put .ini in program folder like XnView MP
Does that require starting the program using xnconvert -ini file.ini ?
When I cut and pasted xnconvert.ini from .../roaming to the program folder, and double-clicked on xnconvert.exe, a new xnconvert.ini file was created in
.../roaming.
If it is necessary to first find the .ini, and then start the program using xnconvert -ini file.ini, that isn't very user friendly even if the option is documented somewhere.
i've just tried, if xnconvert.ini is in folder of xnconvert.exe, no .ini created in roaming...
