slideshow options
stevemd
slideshow options
Post by stevemd »
in the Options for BROWSER-MISC, you can check "use all image files in current folder" if none are selected for Slideshow, which is fine
However I would also like it to automatically pick up the video files as well as jpgs - could an option be added to include video files too?
thanks
Re: slideshow options
stevemd wrote:in the Options for BROWSER-MISC, you can check "use all image files in current folder" if none are selected for Slideshow, which is fine
thanks
So "Use All image & video files in currnet folder" & "Use All image & video files in current folder and its subfolder"?
stevemd
Post by stevemd »
yes - that's it
thanks
stevemd
Post by stevemd »
while we are talking about videos - it would be nice in the thumbnail view if there was an option to show a small movie icon on videos, to distinquish them from stills. Keep the option separate from the info icons, because I like to turn the info icons off, but have the video icon on.
thanks
