XnView MP 0.99.7
Locked
XnView MP 0.99.7
Please, don't post bugs or request in this topic!
You can download XnView MP 0.99.7 here:
Windows x32 ZIP version SHA256: EE782F7857337697506E6FC87F24DCA123F5CF909C894113403205A1C89D4262
Windows x32 SETUP version SHA256: CABB5D918F0D82C09F185E14FEC00EE41517D9751F7771448FC409DDD8221C23
Windows x64 ZIP version SHA256: E526025F69515C6ED87F50E7AA72602418DADB250142D287B2E086FB7B40E912
Windows x64 SETUP version SHA256: 8CC3EBB8EAE6AE0BBD0E35A8B4B12953B1C211E2F0B21FC9C80187DEA44DAB2B
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: 676A690BB3C01E688F97658E6F596D527774DBE07C59FF84E0EB7D758258EBA3
Linux x64 TGZ version SHA256: 890E1AE5FF0BF3CB1CD0161D04611E41599DD524511D7470EE06EA1B632BBDE2
Linux x64 DEB version SHA256: 2989529E5FDF0D87523931D1B2FBF619FA409E4601A6F6B09381B93839D9A318
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.99.7:
2256: [New] Resize: Lanczos2 filter - http://newsgroup.xnview.com/viewtopic.php?t=42816
2255: [New] 'Use checkerboard pattern' in menu - http://newsgroup.xnview.com/viewtopic.php?t=42847
2234: [New] XMP in tooltips - http://newsgroup.xnview.com/viewtopic.php?t=42714
2227: [New] Category menu: Parent label on top of submenu - http://newsgroup.xnview.com/viewtopic.php?t=42575
2226: [New] Album: Import/Export Bridge collection
2246: [New] Batch convert: Antialiasing option for 'Text'
2261: [Bug] Bottom line not visible on HDPI - http://newsgroup.xnview.com/viewtopic.php?t=42783
2260: [Bug] Image is not antialiased when zoom % matches HiDPI scaling - http://newsgroup.xnview.com/viewtopic.php?t=42784
2259: [Bug] Linux: SaveAs always use original date file
2258: [Bug] Join: Need to use sRGB color profile - http://newsgroup.xnview.com/viewtopic.php?t=42853
2257: [Bug] Remove/Extract alpha channel on 8bits image - http://newsgroup.xnview.com/viewtopic.php?t=42824
2254: [Bug] MacOS: EXIF on HEIC file - http://newsgroup.xnview.com/viewtopic.php?t=42838
2253: [Bug] PDF crash
2252: [Bug] Slideshow: Close when using timer at the end - http://newsgroup.xnview.com/viewtopic.php?t=42820
2251: [Bug] Slideshow & high DPI scaling - http://newsgroup.xnview.com/viewtopic.php?t=42811
2250: [Bug] Tag Face: People list not updated - http://newsgroup.xnview.com/viewtopic.php?t=42793
2249: [Bug] Fullscreen info truncated (HTML) - http://newsgroup.xnview.com/viewtopic.php?t=42708
2248: [Bug] Rating in Edit mode doen't update browser - http://newsgroup.xnview.com/viewtopic.php?t=42807
2247: [Bug] Text in statusbar clipped
2245: [Bug] Pan on HiDPI with 1 image pixel = 1 screen pixel
2244: [Bug] Batch rename: option to remove diacritic character - http://newsgroup.xnview.com/viewtopic.php?t=42617
2243: [Bug] Tag Face: XMP metadata not always written - http://newsgroup.xnview.com/viewtopic.php?t=42
2242: [Bug] Tag Face: Crash with grey images - http://newsgroup.xnview.com/viewtopic.php?t=42793
2241: [Bug] Windows: High DPI scaling problem - http://newsgroup.xnview.com/viewtopic.php?t=42756
2240: [Bug] Slideshow a animated file - http://newsgroup.xnview.com/viewtopic.php?t=42792
2239: [Bug] StatusBar: Bad image size in edit mode
2238: [Bug] Resize: Mode not applied - http://newsgroup.xnview.com/viewtopic.php?t=42767
2237: [Bug] Temporary file & reuse - http://newsgroup.xnview.com/viewtopic.php?t=42741
2236: [Bug] Print Selection: aspect ratio of preview image is distorted - http://newsgroup.xnview.com/viewtopic.php?t=42771
2235: [Bug] 'Print selection' not enabled in toolbar - http://newsgroup.xnview.com/viewtopic.php?t=42775
2233: [Bug] Zoom selection & high dpi scale - http://newsgroup.xnview.com/viewtopic.php?t=42718
2203: [Bug] Mac: 'open in finder' dont select/focus file - http://newsgroup.xnview.com/viewtopic.php?t=42632
2232: [Bug] StatusBar not correctly updated if Preview is hidden - http://newsgroup.xnview.com/viewtopic.php?t=42764
2231: [Bug] {File Index} in statusbar - http://newsgroup.xnview.com/viewtopic.php?t=42749
2230: [Bug] Remember last selected filename - http://newsgroup.xnview.com/viewtopic.php?t=42355
2229: [Bug] Open container on category list
2228: [Bug] Edit category's parent doesn't refresh tree - http://newsgroup.xnview.com/viewtopic.php?t=40521
2225: [Bug] Album: Create first show 2 entries
2219: [Bug] {Categories} and 'base path' - http://newsgroup.xnview.com/viewtopic.php?t=41992
2224: [Bug] JXR 128 RGBA - http://newsgroup.xnview.com/viewtopic.php?t=42750
2223: [Bug] Multipage create: Bad orientation for files with EXIF orientation
Changelog 0.99.6:
2222: [Bug] Del file crash - viewtopic.php?f=62&t=42746
Changelog 0.99.5:
2218: [New] Album/collection - http://newsgroup.xnview.com/viewtopic.php?t=28322
2215: [New] Shortcut settings: filter
2209: [New] libJPEGXL 0.6.1 - http://newsgroup.xnview.com/viewtopic.php?t=42715
2206: [New] Filter Images/Videos without folders - http://newsgroup.xnview.com/viewtopic.php?t=42630
2221: [Bug] Viewer -> Browser with a file from category - http://newsgroup.xnview.com/viewtopic.php?t=29310
2220: [Bug] 'Rebuild thumbnails' and thumbnail caching disabled - http://newsgroup.xnview.com/viewtopic.php?t=42717
2219: [Bug] {Categories} and 'base path' - http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
2217: [Bug] Overlay icon with Dpi scaling - http://newsgroup.xnview.com/viewtopic.php?t=42713
2216: [Bug] Label not exported in XMP - http://newsgroup.xnview.com/viewtopic.php?t=42564
2214: [Bug] Panasonic RAW - http://newsgroup.xnview.com/viewtopic.php?t=42430
2213: [Bug] Similar: Crash when closing dialog during a search
2212: [Bug] Change timestamp: Date created always changed - http://newsgroup.xnview.com/viewtopic.php?t=42692
2211: [Bug] Problem after rename file - http://newsgroup.xnview.com/viewtopic.php?t=42698
2210: [Bug] 'Load defaults' in Resize Dialog - http://newsgroup.xnview.com/viewtopic.php?t=42693
2208: [Bug] 4 thumbnails video should use percent frame setting - http://newsgroup.xnview.com/viewtopic.php?t=42709
2207: [Bug] Wrong command for 'Edit XMP' shortcut in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=42707
Changelog 0.99.4:
2201: [New] Better FITS loading
2198: [New] Shift to draw square & circle - http://newsgroup.xnview.com/viewtopic.php?t=42603
2195: [New] Batch convert: Text size unit - http://newsgroup.xnview.com/viewtopic.php?t=42552
2194: [New] Batch convert: Clear transparent pixels
2189: [New] {Categories} in Batch rename - http://newsgroup.xnview.com/viewtopic.php?t=41992
2188: [New] Color used in properties - http://newsgroup.xnview.com/viewtopic.php?t=42555
2184: [New] Batch convert: QR Code - http://newsgroup.xnview.com/viewtopic.php?t=42512
2183: [New] Batch convert: paste file list - http://newsgroup.xnview.com/viewtopic.php?t=42532
2181: [New] Windows: 'Acquire into' - http://newsgroup.xnview.com/viewtopic.php?t=39809
2180: [New] Batch convert: settings to disable format color - http://newsgroup.xnview.com/viewtopic.php?t=42514
2177: [New] Batch convert: ALT+Wheel for previous/next image
2176: [New] Open location code for GPS position - http://newsgroup.xnview.com/viewtopic.php?t=42503
2174: [New] Cleaner face region - http://newsgroup.xnview.com/viewtopic.php?t=39741
2170: [New] 'Lens Model' in template
2167: [New] Menu item to configure panel visibility - http://newsgroup.xnview.com/viewtopic.php?t=42425
2160: [New] lip format - http://newsgroup.xnview.com/viewtopic.php?t=42158
2158: [New] libavif 0.9.2 - http://newsgroup.xnview.com/viewtopic.php?t=42382
2156: [New] JPEGXL: Compression effort - http://newsgroup.xnview.com/viewtopic.php?t=42381
2205: [Bug] can not delete file when entering in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=42471
2204: [Bug] WebP ICC profile - http://newsgroup.xnview.com/viewtopic.php?t=42647
2202: [Bug] Overlay icon with DPI scaling - http://newsgroup.xnview.com/viewtopic.php?t=42638
2200: [Bug] Face's region & orientation - http://newsgroup.xnview.com/viewtopic.php?t=42613
2199: [Bug] MacOS: Delete shared folder - http://newsgroup.xnview.com/viewtopic.php?t=42586
2197: [Bug] Search from context menu - http://newsgroup.xnview.com/viewtopic.php?t=42607
2196: [Bug] Incorrect face tag regions - http://newsgroup.xnview.com/viewtopic.php?t=42597
2193: [Bug] Rating on RAW files doesn't create sidecar - http://newsgroup.xnview.com/viewtopic.php?t=42564
2192: [Bug] Print custom size - http://newsgroup.xnview.com/viewtopic.php?t=42509
2191: [Bug] Batch convert: JPEG XL compression - http://newsgroup.xnview.com/viewtopic.php?t=42566
2190: [Bug] Parent for new category - http://newsgroup.xnview.com/viewtopic.php?t=40554
2187: [Bug] DDS 12bits - http://newsgroup.xnview.com/viewtopic.php?t=42583
2186: [Bug] Update labels after 'Set category' via menu - http://newsgroup.xnview.com/viewtopic.php?t=40147
2185: [Bug] Video Volume problem - http://newsgroup.xnview.com/viewtopic.php?t=37033
2182: [Bug] Batch convert: RAW orientation - http://newsgroup.xnview.com/viewtopic.php?t=42539
2179: [Bug] Wrong EXIF value on RAW - http://newsgroup.xnview.com/viewtopic.php?t=42518
2175: [Bug] Convert: EXIF:Longitude/Latitude show decimal value in 'Text' - http://newsgroup.xnview.com/viewtopic.php?t=42502
2173: [Bug] {EXIF:Altitude} not shown - http://newsgroup.xnview.com/viewtopic.php?t=42502
2172: [Bug] HEIC filename with unicode - http://newsgroup.xnview.com/viewtopic.php?t=42428
2171: [Bug] Set DPI - http://newsgroup.xnview.com/viewtopic.php?t=42490
2169: [Bug] Crash on 1x1 bitmap - http://newsgroup.xnview.com/viewtopic.php?t=42462
2168: [Bug] Slow browser when having a lot of subfolder - http://newsgroup.xnview.com/viewtopic.php?t=42325
2166: [Bug] Rating in detail view
2165: [Bug] Paint: ellipse bug - http://newsgroup.xnview.com/viewtopic.php?t=42443
2164: [Bug] JPEGXL & unicode filename -http://newsgroup.xnview.com/viewtopic.php?t=42422
2163: [Bug] Sort folder by comment - http://newsgroup.xnview.com/viewtopic.php?t=42404
2162: [Bug] X3F on MacOS/Linux - http://newsgroup.xnview.com/viewtopic.php?t=42344
2161: [Bug] {EXIF:xA...} fields - http://newsgroup.xnview.com/viewtopic.php?t=42279
2159: [Bug] RAW EXIF Camera fields - http://newsgroup.xnview.com/viewtopic.php?t=42371
2157: [Bug] Similar: Sort - http://newsgroup.xnview.com/viewtopic.php?t=42372
2155: [Bug] XMP list fields in Batch rename - http://newsgroup.xnview.com/viewtopic.php?t=42023
2154: [Bug] Batch convert: Disable mutli core when PDF - http://newsgroup.xnview.com/viewtopic.php?t=42359
2153: [Bug] Animated webp - http://newsgroup.xnview.com/viewtopic.php?t=42383
2152: [Bug] GPS writing Negative value - http://newsgroup.xnview.com/viewtopic.php?t=42378
2151: [Bug] Image size on RAW - http://newsgroup.xnview.com/viewtopic.php?t=42349
Changelog 0.99.1:
2150: [Bug] Category Sets: Font & remove - http://newsgroup.xnview.com/viewtopic.php?t=42366
2137: [Bug] BLP - http://newsgroup.xnview.com/viewtopic.php?t=42315
2149: [Bug] Dark Theme & Details mode - http://newsgroup.xnview.com/viewtopic.php?t=42364
2148: [Bug] Slow zooming after loading image file - http://newsgroup.xnview.com/viewtopic.php?t=4236
2110: [Bug] Setting Filelist-Audio - http://newsgroup.xnview.com/viewtopic.php?t=42073
2147: [Bug] XMP-CF writing - http://newsgroup.xnview.com/viewtopic.php?t=42350
2146: [Bug] Search file count - http://newsgroup.xnview.com/viewtopic.php?t=42358
2145: [Bug] Batch convert multipage file convert one page - http://newsgroup.xnview.com/viewtopic.php?t=42359
2143: [Bug] X3F - http://newsgroup.xnview.com/viewtopic.php?t=42346
2118: [Bug] PNG: 8bits + transparency - http://newsgroup.xnview.com/viewtopic.php?t=42103
2142: [Bug] PNG crash - viewtopic.php?t=42354
2141: [Bug] Time always changes to 00:00:00 - http://newsgroup.xnview.com/viewtopic.php?t=42352
2140: [Bug] Play only once animated file - http://newsgroup.xnview.com/viewtopic.php?t=42342
2139: [Bug] No auto refresh in Export>JPEGXL - http://newsgroup.xnview.com/viewtopic.php?t=42336
Changelog 0.99.0:
2134: [New] Qt 5.15.6
2126: [New] JPEGXL 0.5
2095: [New] libwebp 1.2.0
2077: [New] LibHeic updated, EXIF-XMP output
2076: [New] LibJPEGXL updated
2075: [New] Libraw instead of dcraw
2132: [New] Batch rename: ignore extension for # - viewtopic.php?t=42244
2128: [New] Set DPI - viewtopic.php?t=42134
2124: [New] Batch convert: Environment vars - viewtopic.php?t=42125
2113: [New] JPEGXL options & export - viewtopic.php?t=42071
2112: [New] Setting to hide mouse in fullscreen
2102: [New] Search: Dialog is no more modal
2090: [New] Option to disable two-pass rendering - viewtopic.php?t=31643
2089: [New] Edit XMP: Fotoware custom field support
2084: [New] Button to edit text 'Add Text'
2138: [Bug] No undo after saving a screenshot - viewtopic.php?t=42285
2137: [Bug] BLP - viewtopic.php?t=42315
2136: [Bug] Menu items not disabled - viewtopic.php?t=42311
2135: [Bug] Slow startup on Windows - viewtopic.php?t=39920
2133: [Bug] Open second image in fullscreen & one instance - viewtopic.php?t=42277
2131: [Bug] Search similar problems - viewtopic.php?t=42227
2130: [Bug] 'Select first item' not working - viewtopic.php?t=42257
2129: [Bug] Batch convert: FTP + Keep structure
2070: [Bug] Linux: Drag&Drop copy not move - viewtopic.php?t=41768
2127: [Bug] Batch convert: Bad output for NConvert - viewtopic.php?t=42152
2125: [Bug] .clip & temp files - viewtopic.php?t=42157
2122: [Bug] Drag&Drop problem - viewtopic.php?t=41975
2123: [Bug] Lossless transformations disabled - viewtopic.php?t=42101
2121: [Bug] XBS button doesn't work in viewer mode - viewtopic.php?t=42094
2120: [Bug] XMP sidecar attached to RAW - viewtopic.php?t=37291
2119: [Bug] Filtering & open view - viewtopic.php?t=42056
2118: [Bug] PNG: 8bits + transparency - viewtopic.php?t=42103
2117: [Bug] Preview's position - viewtopic.php?t=38740
2116: [Bug] PNG: 24bits + transparency - viewtopic.php?t=42018
2115: [Bug] Folder sorting - viewtopic.php?t=42098
2114: [Bug] 'Rating+Label' thumbnail label
2111: [Bug] Settings>Toolbar - viewtopic.php?t=42072
2110: [Bug] Setting Filelist-Audio - viewtopic.php?t=42073
2109: [Bug] Batch Convert: Export all pages into single page file - viewtopic.php?p=170725
2108: [Bug] IPTC encoding (utf8) - viewtopic.php?t=42044
2107: [Bug] Automatic crop & 32bits picture
2106: [Bug] Write format list - viewtopic.php?t=42054
2105: [Bug] XMP Create Contact - viewtopic.php?t=42014
2104: [Bug] Can't read or write negative altitude value - viewtopic.php?t=42050
2103: [Bug] Resize must remember previous settings - viewtopic.php?t=42048
2101: [Bug] XMP fields in Batch rename - viewtopic.php?t=42023
2100: [Bug] Print in landscape not possible - viewtopic.php?t=41889
2099: [Bug] {ratio} must show aspect ratio when possible - viewtopic.php?t=42031
2098: [Bug] Batch convert: WebP export for NConvert - viewtopic.php?t=42025
2096: [Bug] Edit Mode: Rating hidden when toolbar is on the left
2094: [Bug] White Balance in Edit mode
2093: [Bug] Info text not correctly aligned - viewtopic.php?t=41954
2092: [Bug] GIF pause - viewtopic.php?t=41737
2091: [Bug] Rating-Color label written in sidecar - viewtopic.php?t=41308
2088: [Bug] Theme on startup wizard & better color for dark theme
2087: [Bug] Curve crash
2086: [Bug] Invalid {WidthMm} and {HeightMm}
2085: [Bug] Invisible text in thumbnail's labels when 'Use format color' is disabled
2083: [Bug] Parent category not applied on Enter - viewtopic.php?t=41979
2082: [Bug] Paint: Shortcut for undo/redo - viewtopic.php?t=41969
2081: [Bug] SPACE in category pane - viewtopic.php?t=41982
2080: [Bug] Slideshow: file list is always sorted by filename - viewtopic.php?t=41986
2079: [Bug] No GPS pane if 'Preview' is disabled - viewtopic.php?t=41930
2078: [Bug] Slideshow: no rating/color label - viewtopic.php?t=41929
2074: [Bug] Info not showing on entering fullscreen - viewtopic.php?t=41964
2073: [Bug] Face tags not shown - viewtopic.php?t=41958
2072: [Bug] Numerical sort (by Date) for files with same date - viewtopic.php?t=41960
2071: [Bug] Clipboard corrupted at exit - viewtopic.php?t=41950
AussieActive
Re: XnView MP 0.99.7
Post by AussieActive »
Fixed. Awesome! Thanks 😊
Locked
