heic output - 0 byte files
in xnconvert 0.94 I wanted to test the heic format, but it just creates 0 byte files. So it doesn't support it as an output format?
txh
txh
Re: heic output - 0 byte files
Hi, it is on Windows 10.
C:\Users\Tapio>ver
Microsoft Windows [Version 10.0.19043.1348]
Please check this file, thank you!
https://www.dropbox.com/s/e30pqxc6wojy5 ... .heic?dl=0
This is my XNConvert result:
Started at: Mi Dez 1 10:23:30 2021
C:\Users\Michel\Desktop\20191106_121227_stefanie.heic : loading
C:\Users\Michel\Desktop\20191106_121227_stefanie.heic 0x0x0 : failed
Input files: 1
Extracted pages: 1
Total Duration: 0 second(s)
Finished at: Mi Dez 1 10:23:30 2021
do you have a preview in Input tab? It is XnConvert 1.94 x64?
Setup.
- Tried under a different Windows user, same bad result.
- Also, the HEIF image extension app of Microsoft is installed. I uninstalled it (PS as admin, "Get-AppPackage Microsoft.HEIFImageExtension | Remove-AppxPackage") - Uninstallation was successful, but XNConvert still creates the error.
i've tried with XnConvert 1.94 x64 on Windows 10, and no problem to convert heic files. Could you send me a heic used?
See above posting: viewtopic.php?p=173922#p173922
You can download the unaltered file from the dropbox! See download button to the top left.
it works here, so you can't convert with XnConvert but you can with XnView MP 0.99.4?
Yes that works. XNView batchconverter also shows image miniatures, xnconvert does not.
Nice hint, didn't know XNView batch converter is a complete UI itself, so now I can use it - thx for adding QR Code, I noticed it...
