Xnshell not support windows dark theme
masktao
Post by masktao »
hi:
i like Xnshell. use it long time. and replace acdsee's shell. but i found it's not work for windows 10 dark theme
if chose no submenu, then there is no dark menu
xnview shell 4.1.2 & windows 10 21H1
hope your team can make update fix bug
Re: Xnshell not support windows dark theme
new version will fix it
Wolverine1977
Post by Wolverine1977 »
Windows 11 Pro x64 using 4.1.5:
If I choose No Sub menu in the options the whole context menu dark theme is disabled?
Also if I All - the context sub menu is dark but when I go into options its still in the light theme - is this expected.
Thanks
