0.99.1: Playback for video and seek bar for videos don't play or are slow
stevehero
Post by stevehero »
XnView: MP 0.99.1 - 64 bit
OS: Windows
The seek bar is slow or sometimes doesn't progress.
The video playback is also slow.
I'm not sure if these are connected so I made one bug report for the two.
Effect: Videos don't play correctly and or seek bar doesn't move.
1. Play an mp4 video file.
2. Some videos play and some don't and the seek bar either works or it doesn't.
See specs of a typical video that is laggy to play and the seek bar doesn't move.
Video
Format	AVC
Width	640
Height	640
Duration	15 s 49 ms
Bit rate	1 100 kb/s
Aspect ratio	1.000
Frame rate mode	CFR
Frame rate	29.970
Audio
Format	AAC
Duration	15 s 93 ms
Bit rate mode	VBR
Bit rate	1 405 b/s
Sampling rate	44.1 kHz
Frame rate	43.066
Compression mode	Lossy
Re: 0.99.1: Playback for video and seek bar for videos don't play or are slow
Please try to use windows codecs by changing in xnview.ini
useInternalVideoPlayer=false
stevehero
Post by stevehero »
Still the same issue.
One file is playing fine which is 61MB and the other which is double that and the exact same codec is not.
The faulty one will play if I place the seek bar towards the end and then it'll work when I click anywhere. Seems to be a buffering issue even though the content is local.
One file is then playing slow for about 20 seconds and then it'll eventually start playing.
Here's the codec info:
Video
Format	VC-1
Encoded date	UTC 2009-09-02 21:29:19.356
Width	1280
Height	720
Duration	9 min 55 s 229 ms
Bit rate	3 328 kb/s
Aspect ratio	16:9
Frame rate	29.970
